DPF fault can anyone advise me???
a3 turbp Mar 13, 2013
  1. a3 turbp
    a3 turbp Member
    77
    Hello ive been a member for a few years but have only recently come back onto the audi scene.
    I've just purchased a A4 B8 2.0tdi 143 DPF avant and the other day the emissions control light came on, so i drove the car in regen mode and it went out, however two days later it came on again, I plugged it in and it came up with a fault of exhaust pressure sensor. I was looking through my books and service history and noticed the car had a DPF pressure sensor fitted oct 2011 at a audi dealership so I rung them and they confirmed this at that i may be able to get it replaced under warrenty but that there are two pressure sensors on the DPF so could'nt say for sure if it was the one they replaced without doing a diagnostic them selves at a cost of £103! for them to tell me what i had already told them! ive been doing a little research and it appears there is only one pressure sensor and three temp sensors so i'm wondering if theyre trying to pull a fast one???
    any advice/help will be greatly appriciated
    thanks
  2. hollow
    hollow Well-Known Member
    1,403
    162
    knowing audi they were trying to pull a fast one . for you to buy the sensor yourself is cheaper than a diagnostic off them . with things like this you either bite the bullet and buy one ,or hope you have a mate willing to let you try his first .
  3. a3 turbp
    a3 turbp Member
    77
    Don't i have to programme the new sensor to my ECU though?
  4. hollow
    1,403
    162
    nope ,done quite a few make sure vacumn pipe is clear before fitting new sensor though by blowing air down it . fit sensor,clear faults and force a regen .
  5. a3 turbp
    a3 turbp Member
    77
    thats great thanks, how do i force a regen?
  6. hollow
    1,403
    162
    [Select]
    [01 - Engine]
    [Coding-II - 11]
    • Enable Regeneration by Entering 21295.
    [Do It!]
    [Meas. Blocks - 08]
    Select both Groups at once 070 and 075.
    [Go!]
    MVB 070.1: Regeneration Status (xxxxxxx1 = Normal Regeneration active, xxxxxx1x = Forced Regeneration active)
    MVB 070.3: Regeneration Counter/Timer
    MVB 075.1: Exhaust Gas Temperature before Turbo Charger
    MVB 075.2: Exhaust Gas Temperature before Particle Filter
    MVB 075.3: Particle Filter Load
    MVB 075.4: Exhaust Gas Temperature after Particle Filter
    Now Start the Driving Cycle and keep watching the Measuring Blocks (2nd Person required).
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    if yours is a common rail you can do the regen without driving it .
    best read here easier than explaining it all .
    Diesel Particle Filter Emergency Regeneration - Ross-Tech Wiki
  7. a3 turbp
    a3 turbp Member
    77
    Sorry i don't have VCDS i only have a basic scanner
  8. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,250
    583
    By looking at live data using VCDS for example, not scanner, it's fairly easy to diagnose if the sensors are working. I'd look at having this done before you spend money on a sensor.
    Rick
  9. gregpot2000
    gregpot2000 Member
    55
    It does need to be adaptored though and programmed that way?
  10. helal786
    helal786 New Member
    24
    It needs to go on VCDS, most garages charge about £35
    If the sensor needs replacing then it needs to be adapted too.
    Where about in the UK are you?
  11. Zafi
    Zafi Well-Known Member
    1,232
    302
    Mine was exactly same. Turned out to be the sensor. £85 fitted at Vastech in Northallerton.
