dpf delete
tubby Mar 15, 2012
  1. tubby
    tubby Member
    51
    hi does anyone know when a company does a dpf delete and remap on the dpf can its self do they remove the inners or have a straight pipe manufactured thanks steve
  2. GWhittell
    GWhittell New Member
    Hi Tubby,
    I'm going to Shark Performance tomorrow to have the DPF removed and a remap. It's been with Audi for fours days and the car has come back worse than it went in! I have lost all confidence in them so spending another wad of cash with them isn't an option.
    I think they're going to cut open the DPF, remove the contents and weld it back up again. I'll know more tomorrow I guess!
    BTW I have an A3 Tdi 170 DPF (well, for the next 10 hours then I guess it'll be an A3 Tdi 210 (no DPF) :)
    I'll let you kow how I get on....
    Cheers..
  3. tubby
    tubby Member
    51
    thanks mate im having issues with mine,im a mechanic so im gonna do myself and i have somone to remapp it,i was thinking the same remove cut open remove the contents then weld up let me know how you get on thankls steve
  4. N8
    17,163
    718
    Shark HQ fella in Mansfield.
  5. GWhittell
    BTW if it's an A3 quattro like mine it's a pig of a job apperently. I'm quite competent home mechanic but it sounds too much work for my axle stands and stick welder!
  6. N8
    17,163
    718
    Quattro is more of a pig, but no problem for the guys @ Shark ;)
  7. tubby
    tubby Member
    51
    n8 do you know how the filter is removed is the can cut and the inners removed and re welded,steve
  8. N8
    17,163
    718
    Not 100% sure brother, I just know the mechanic does his magic, and they are great & drive great :wub:
  9. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,474
    646
    i know a couple of places in sheffield
    but ur miles away in london
  10. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,241
    575
    We can do it, but a little out of your way!
    Rick
  11. matthew999
    matthew999 Member
    145
    i had mine done by richard at rsh performance, he did it including an evolutonchip remap for 720. I have an A4 Tdi quattro and im very happy with it. FYI he said that he takes some buts out of the engine bay and it can be pulled up and out its tight but does come out, lol that sounds rude!
    cheers
    matt
  12. S3AMK20VT
    S3AMK20VT Member
    165
  13. murran
    murran Well-Known Member
    1,545
    39
  14. APAutomotive
    APAutomotive Shark Performance Shropshire
    82
    You can either source a bypass pipe (miltek?) or cut your original one open & knock the internals out then re-weld.
    Quattro is a right pain to do
  15. devil_vas
    devil_vas Member
    32
    Welcome in Bulgaria ;)
  16. Baza1819
    Baza1819 Member
    254
    Cost me £150 for dpf removal
    £50 for dpf delete
    £200 for remap !
    I think you's may be getting exploited with some on the prices your getting.....
  17. g00se
    g00se Active Member
    268
    26
  18. devil_vas
    devil_vas Member
    32
    just for comparison
    we do it (Bulgaria) for £300 incl. DPF removal mechanically and software, remove catalyst and performance remap on dyno :blink:
  19. dantdi
    dantdi ...
    516
    Seen on AMD Essex site they are now doing DPF removal now.
  20. g00se
    g00se Active Member
    268
    26
    or if its closer to you, you could try Simon @ AMD Technik in Woking, Surrey ?
    goose
