  1. Robhullfury
    Robhullfury New Member
    26
    Hi, I've had a search but I'm confused.
    my dpf light keeps coming on and after burning it off in 4th at 2k it goes off but comes on again after a month or so. Is it possible to physically take the dpf out to clean it and remove the soot?
    I cant seem to get my head round the replies from previous posters.
    thanks
  2. Chillout
    Chillout Active Member
    609
    50
    Dpfs can be removed and chemically cleaned I saw a company called dpf genie online might be worth a try.
  3. c_w
    c_w Well-Known Member
    1,163
    87
    Depending on your driving type it is normal for it to come on from time to time. Urban stop-start driving and short trips where the car doesn't come up to temperature clog the DPF up pretty quickly. I find mine comes on perhaps once or twice a year, normally after a period of short trips. The car is generally used for longer commutes where it doesn't come on.
    I disected my DPF off my old 170 and it was really clean inside, almost no ash at all as the normal regeneration process really does burn it off. So if you did have it "cleaned" it will only do the same thing in a matter of days IMO.
    To avoid it get it removed and remapped. But make sure they "Gut" the DPF and re-weld it so it looks factory at a glance.
  4. Jinxy-S3
    Jinxy-S3 Member
    59
    17
    DPF delete and remap had it on my Leon FR genuinely night n day between them bags of torque and better power delivery (smoother)
  5. davesimmo
    davesimmo Member
    179
    13
    DPF delete is now an MOT failure.... Ok gutting it... But they will soon latch onto this. :wtf:
  6. Jinxy-S3
    Jinxy-S3 Member
    59
    17
    How's your average garage gonna know ? If the emissions are under..... Sweet
  7. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    882
    And diesels only get a smoke test in the MOT anyway.
    Jinxy-S3 likes this.
  8. Rhyso
    Rhyso Well-Known Member
    1,463
    295
    In the 12 months prior to removing my DPF i never had the DPF light come on. My daily commute was 4 miles in which time the car hardly got any temperature into it. By all accounts thats prime conditions for clogging the DPF
    The light generally comes on because there is a fault. Id advise getting it checked out before you end up with an expensive bill.....
  9. c_w
    1,163
    87
    The way it's driven in urban environments also affects it too. If my girlfriend drives the car the light is more prone to come on as she accelerates harder than I do!
  10. Jinxy-S3
    Jinxy-S3 Member
    59
    17
    Your bird accelerates harder than you do ? Dunno if I'd be shouting that on a car forum lol :)
    Mikemc and Rhyso like this.
  11. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    Quite easily, tapping the empty DPF with a spanner, you'll know its been gutted.
    Have a look into "terraclean" cleans the whole engine and exhaust system including the DPF of all carbon and soot build up.
  12. c_w
    1,163
    87
    It's a TDI, bought it to maximise mpg :arco: I don't mean she wheelspins off everywhere, she drives like 95% of the population in urban driving; unnecessary acceleration without anticipation of the next red light, joining the race to 37mph, harsher throttle use but not actually going faster anywhere!
