Downpipe removal on 2.0 TDI Quattro
Cyrix Jan 31, 2013
  1. Cyrix
    Cyrix Member
    292
    23
    I'm having a bit of an issue with my 140 quattro.
    I'm in the process of swapping out the turbo (suprise, suprise) but can't seem to get the downpipe out, does anyone have any hints or am I going to need to drop the subframe?
  2. NHN
    29,563
    1,779
    With the fwd it just pops of the turbo & goes through the gap between subframe & exhaust channel as such, as I've done it numerous times now & got to do again possibly this weekend arrgghhh, but guessing with the quattro shaft, thats blocking the exit as such, so looks like sub has to drop, I will check elsawin when got a minute to be sure.
  3. NHN
    29,563
    1,779
    Whats the engine & gearbox code?
  4. Cyrix
    Cyrix Member
    292
    23
    Yeah, I've dropped the propshaft and can see how it would be real easy on a FWD.
    If you wouldn't mind checking that would be great.
  5. Cyrix
    Cyrix Member
    292
    23
    Engines a BKD, unsure on the box
  6. NHN
    29,563
    1,779
    Inside page of service book shows engine & box code.
  7. Cyrix
    Cyrix Member
    292
    23
    Engine is BKD gearbox is FUQ
  8. Cyrix
    Cyrix Member
    292
    23
    The answer is, it comes out with no need to remove anything else.
    BFI prevailed ;)
  9. NHN
    29,563
    1,779
    Sorry mate, tiring day & forgot to reply, buttt, I checked in elsa for your codes & it only showed one route for either 4wd or fwd, as I advised before, drop down through the sub/chassis gap.
