downpipe fitment on hybrid turb
James TQ Dec 27, 2012
  1. James TQ
    James TQ Member
    561
    i have bought a hybrid turbo and before i get it fitted i want to buy some more mods, looking at my k03 now it looks like where the downpipe meets the turbo it had 3 bolts on the flange wheres the k03/s hybrid has a 4 bolt flange, is this normal and do i have to get a s3 dp or a a3 quattro dp? thanks
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Post a picture, sounds like a k04 hybrid.
  3. James TQ
    James TQ Member
    561
  4. <tuffty/>
    21,255
    3,880
    PWD protected mate... link to the images....
  5. James TQ
    James TQ Member
    561
  6. <tuffty/>
    21,255
    3,880
    I'd look again then mate as that turbo in the pic and the one on your car are K03 based so yours will have a 4 bolt fitting.... I'd have a look on FaceBook for the Relentless K04 page and have a chat with Sam about a downpipe for that... the A3 quatty DP is differnt to both the S3 and the FWD A3...
  7. James TQ
    James TQ Member
    561
    ok ya, i thought the s3 and quattro dp were the same shape just different flanges so i need a 4bolt dp to fit this, i can see this is going to just be a nightmare!!
  8. <tuffty/>
    21,255
    3,880
    Whyso?... to fit a K03 hybrid to a K03 car you more or less bolt it straight on... you will need injectors from a 210/225 K04 turbo'd car, a MAF tube from the same car and then mapped to suit...
    The DP you currently have will bolt straight on to the hybrid... if you want a 3" one then pop on to facebook...
  9. beachbuggy
    1,931
    201
    Out of interested where's that from and what bhp is it rated at?
  10. James TQ
    James TQ Member
    561
    i mean finding a dp will be a pain, before the hybrid goes on im going to get a new clutch and flywheel as its a 99' with 114k and no record of a change, also getting the dp befor,
    would you advise rods, if so what dimensions do i need :) thanks
  11. James TQ
    James TQ Member
    561
    i bought it from a kid who split his a3 build by universal turbos not sure on what spec tbh just listed as k03s/4 hybrid
  12. James TQ
    James TQ Member
    561
    built 3 months ago, no play in shaft seems good nick
  13. beachbuggy
    1,931
    201
    I'd hazard a guess then its a k04 based hybrid, whether it is just a k04 cold side hybrid or hotside as well its not possible to tell from the pictures. If your going to do it right, then get a ported exhaust manifold, b5 is what I recommend, and really would be needed to get this flowing well. You'll have to sort the water pipes as well you need a k04 tip which won't direct fit
  14. James TQ
    James TQ Member
    561
    i was thinking about getting it ported, its a normal a3 mani? is the tip size a k04 or 03? what needs to be done to the water pipes? b5 is too far for me to go its over 3hr drive i think i will use parsons its just over a hour to do the work, im ot planning on doing it anytime soon just doing bit by bit if i see something pop up for a fair price ill knab it, this turbo was £300 posted which i was pleased with, but as i saw clutch and poss rods before anything thanks for the info
  15. <tuffty/>
    21,255
    3,880
    Fairly sure the A3 TQS uses 19mm rods... the K03 hybrids are quite spiky and with the grip a quatty has its advisable to do rods tbh.... personally would use rifle drilled ones too...
  16. James TQ
    James TQ Member
    561
    where is the best place to shop for them, what brands are best to look for? sorry for all the Q's
  17. James TQ
    James TQ Member
    561
    also 19mm by what mm?
  18. <tuffty/>
    21,255
    3,880
