Downpipe and sports cat ebay
Crazypete00 Mar 13, 2014
  1. Crazypete00
    Crazypete00 Active Member Audi S3 Audi A4
    495
    61
  2. Adam P
    Adam P Active Member
    539
    178
    43
  3. <tuffty/>
    21,367
    3,932
    Difference is one comes with a cat and the other doesn't
  4. Crazypete00
    495
    61
    ye one has the sports cat the other de cat. im tempted with it, hopefully its a correct fitment.
  5. Adam P
    539
    178
    43
    Makes sense, think i will go for a relentless setup tho.
    Crazypete : if you get this item can you let me know how good the fitment is?
  6. <tuffty/>
    21,367
    3,932
    Its the righ one for the S3 yes, don't use the supplied turbo/DP gasket as it will eat itself in days... buy an OE gasket (not expensive) for that..
    You can 'get away' with using the one for the 2 bolt flange but this too may leak and fall apart over time so I generally use a 300 deg high temp silicon sealant
    Be aware though that quality control on these vary and on occasion they have been known to touch enough to rattle... there is a little movement on the turbo studs to help but some have found they need a strategic dent to clear
    Adam P likes this.
  7. Crazypete00
    495
    61
    thanks, ye im tempted with it, im replacing the turbo anyway so have new gaskets and the oil feed line. also replacing my flywheel and clutch so its a perfect time to be doing it all.
    i cant remember what sam was selling the relentless ones for.
  8. Crazypete00
    495
    61
    just checked its an XS power DP and cat. also while im on the case, i just got quote £190 for turbo gaskets, bolts and oil feed pipe, does that sound right?
  9. daneastwood
    daneastwood daneastwood
    23
    This chap on ebay is one of my friends, I have one of the downpipes withought the sports cat on my car and its really good, like tufty says the gaskets arnt the best i replaced the one at the turbo but really cant fault the quality other wise. The welds are flawless allround and the fit is spot on. If you want one I can put you in contact with him instead of going through ebay.....
    Hope this helps
    Dan
  10. DarrenS3
    DarrenS3 Member
    62
    Hi, Sorry to resurrect an old thread, but I am looking for a sports cat and wondered if your friend sells them and if you know whether they are any good and will pass the mot. Cheers!
  11. Cj_sat69
    Cj_sat69 Member
    77
    12
  12. <tuffty/>
    21,367
    3,932
  13. Cj_sat69
    Cj_sat69 Member
    77
    12
    Do you need to lower the subframe and stuff to fit a downpipe or is there enough room for it to go up, Went to one place and they said they have tio drop the subframe and steering rack to get it on.
  14. <tuffty/>
    21,367
    3,932
    Not to fit one like this no... but... if you expect to remove the OE one in one piece then yeah you will have to drop it... I normally cut through the flexi with an air chisel as this is the softest part... I also cut off the hanger bracket to allow the OE DP to turn to get it past the rack
    Normally have to grind/chisel the CAT fixing nuts off too as they corrode badly
  15. Cj_sat69
    Cj_sat69 Member
    77
    12
    Cheers for the update
    Will i have issues with the bolts on the turbo? i heard they can snap off too.
  16. <tuffty/>
    21,367
    3,932
    Anything is possible... too subjective to say but it does happen
