Down pipe and de cat pipe
Grale1 Aug 6, 2012
  1. Grale1
    Grale1 Active Member
    795
    44
    Hi can someone tell me if I fitted a new down pipe and de cat would I get any lights come on in the dash? That would need to be turned off as I'm looking into getting one
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    What engine code have you got? The AMK and BAM engines has post cat lambda sensors that will throw the engine check light on the dash with a de-cat.
  3. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    but very easily coded out .
  4. Grale1
    795
    44
    I have an a3 1.8t AGU
  5. harvey01
    harvey01 Member
    523
    9
    ive got a 3inch down pipe and decat and i fitter a lamder spacer and the light never came on , mine is an amk
  6. Grale1
    795
    44
    Sorry for my thickness but what do you mean by lamber spacer
  7. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,127
    355
    No agu won't throw up a code
  8. harvey01
    harvey01 Member
    523
    9
    its a fitting you screew in to the lamder hole and it pulls the lamder out of the flow so it thinks there is a cat there
  9. moredoor
    moredoor Member
    160
    Like others have said, on AGU no EML light will pop up.
  10. Prawn
    11,506
    3,415
    Another reason why an AGU A3 is better than an S3 :laugh:
    WorkInProgress likes this.
  11. knoxie
    knoxie K4OXE
    619
    15
    where can you get these from? will it go into limp mode if it throws a wobbly?
    i have an AMK
  12. Westy
    17,443
    1,103
    You won't get limp mode just a engine light onthe dash.
  13. harvey01
    harvey01 Member
    523
    9
    hi mate i got mine of ebay there are two types i got the L shape type, there are strate ones but there isnt much space in the trans tunnel for the strate ones . i typed lamder spacer in to ebay and i think a couple of pages came up . hope this help shttp://www.ebay.co.uk/itm/Lambda-Spacer-60deg-Angled-Golf-R32-o2-Sensor-Adjustable-Extender-Exhaust-Decat-/221089335613?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3379f3893d
  14. Grale1
    795
    44
    I got my 3" de cat and down pipe today, which section would I have to put the lamber sensor in?
  15. <tuffty/>
    21,153
    3,834
    lambda goes in the first section... it will be easy to notice as this will be in a similar position as the one you remove... :)
  16. Grale1
    795
    44
    Do I need to use a spacer as someone has said as I don't want any lights to up on the dash
  17. <tuffty/>
    21,153
    3,834
    Not for the main lambda... you only need a spacer for the post cat lambda if you actually have one which I don't believe you have...
    The pre cat lambda is used by the ECU to help control fuelling on idle and part throttle... the post cat lambda is used for checking the effectiveness of the cat which is why they throw a code when decat's are fitted as it thinks the cat is faulty..
    I suspect you won't need to worry about this...
  18. Grale1
    795
    44
    I have AGU engine code, I hope to get it on tomorrow and see what diff fence it will make,
  19. Prawn
    11,506
    3,415
    Tufty, in a hugely rare shocker you got pre and post the wrong way round. get some rest dude, it's been a long week!
  20. Prawn
    11,506
    3,415
    And as tufty says, no lights when you decat an AGU :)
  21. <tuffty/>
    21,153
    3,834
    Arse... yeah :(
    Tired ++... I'll edit (coz I can ;P)
  22. Grale1
    795
    44
    Cool, ok so I just undo the lamber sensor from the cat and screw it into the first hole on the new dp and decat and would I notice any difference with a de cat and dp
  23. Grale1
    795
    44
    Hopefully going to do this today, best it best to put wd40 on all the bolts to help loosen them, as I would hate to snap a stud off on the turbo, when fitted will I notice much in regards to being a bit more responsive as it will be less restrictive
  24. pthackeray22
    pthackeray22 Member
    92
    fitted mine only last week, threw no codes up and well i noticed a difference, although my stids was that tight the nuts had to be heated up to get the original one off, but definatley well worth it, i also fitted a 1.9tdi boxless centre section with little modification, and already had the back box and totally different in sound and is alot more responsive,
  25. Grale1
    795
    44
    Got mine on, but we're the centre section goes into what would of been the cat is blowing, so I'll have to take it to exhaust place tomorrow to get what I'm hoping would just be a new clamp as I don't the amateur thing and used the old clamp
  26. Grale1
    795
    44
    Had the new clamp fitted this morning from the decay to the center section, now when I'm driving I can hear a whistle from the turbo , is this normal as the pipe is a lot bigger so breathing better? I done all bolts as tight as I could so shouldn't be blowing from the turbo
  27. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Mine makes a bit more noise too and am pretty sure mine is not blowing so i think its just as you said its the better breathing ability making more noise :)
  28. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Just go for a bit of both.... lol.
  29. Grale1
    795
    44
    Just can't wait till I get my remap done, still a couple of things to do to it before I go there in a few weeks
  30. Grale1
    795
    44
    Has anyone else had problems with the decat keep blowing where it's clamped to the center section? I had a new clamp put on last Monday and I've just got home and noticed that its blowing again, hoping to jack it up tomorrow and tighten the clamp up, had have noticed small amount of vibration in the exhaust since fitting dp and decat
  31. pthackeray22
    pthackeray22 Member
    92
    not had any probs with mine, and i used the old clamp, as it has already shaped to my exhaust as such, did you put any exhaust paste on
  32. A3 NICK
    A3 NICK BOOOOOOOOOST!!!
    52
    Is it ok to fit a decat and downpipe on my AGU before i have had it stage 2 re-mapped? I have fitted it and now doesn't seem to pull as well as before :/ any thoughts?
  33. pthackeray22
    pthackeray22 Member
    92
    shouldnt be anything to do with your decat pipe , if anything it should let it breathe more than before,
  34. A3 NICK
    52
    Thanks pthackeray22, Im already running a stage 1 revo map but didn't fit the decat/downpipe until after it was done. So this shouldn't be making the car less responsive?
  35. pthackeray22
    pthackeray22 Member
    92
    possibly.... you may need to go get your map tweaked , or stick with what you know and put your cat back on, im sure the tuffty a3/s3 guru will be along at somepoint today and will shed some more light,
  36. Grale1
    795
    44
    Any recommendation for back boxes? Thought my decat was blowing but turned out to be a small hole in the rear box which after 5 mins of letting it warm up to go out on Sunday the pipe from the box to the center section has snapped in two
  37. Westy
    17,443
    1,103
    The Miltek systems are a popular choice on here. I have a Miltek cat back system and I love it. You can pick up a full system for around £300 on eBay 2nd hand if you keep your eyes peeled.
