down on power, logs inside!
karl210 Jul 23, 2012
  1. karl210
    karl210 Member
    324
  2. Westy
    Westy Well-Known Member
    17,442
    1,100
    Have you tried unplugging your MAF and running the car? If it feels faster/better then you probably require a new MAF.
  3. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Can you log wg DC and also command v actual boost
  4. aragorn
    17,956
    701
    he did in the second log!
  5. badger5
    9,374
    1,916
    224bhp worth of air which is less than you would expect from 1.3bar of boost... and injector duty cycle looks quite high..
    suspect tired maf.. from the logs
  6. karl210
    karl210 Member
    324
    Tried the maf and it didnt feel noticeably different, can i measure ohms or anything to check it? saying that after i did this run i did clean it with brake cleaner and the car did feel slightly sharper.
    Unfortunately i dont have vcds yet and i dont want to keep troubling poor Dave to meet me for a run but ive got my eye on the kit on ebay so should hopefully be able to do another run in the near future.
    Also since doing this i adjusted the wastegate 3 turns for more boost which seems to have picked the car up alot but occasionally when booting it when it gets to 4800 it really dies and even struggles to get to the limiter so im guessing thats limp so im going to back it off about a turn, but it still feels very laggy.
    EDIT: Ive also had the injectors ultrasonically cleaned since this log so im not sure if that makes any difference to the duty cycle? thanks for the help guys
  7. beachbuggy
    1,931
    201
    Oh yeah :)
  8. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I don't mind doing another logging session if there's particular blocks that the community would like to see? Now things have started to settle down after the house move I have a bit more time available for motoring shananigans...
  9. karl210
    karl210 Member
    324
    your'e a star mate thanks alot, the engine changes its personality every time i drive the bloody thing! I could do with getting my own lead and software really. Whenever your free mate just let me know cheers
  10. Westy
    17,442
    1,100
    You've moved. Show me them garage pics :yahoo:
  11. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I'll get some tonight :)
  12. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Will do mate. Will also reply to your PM shortly.
