Double din install
vwgtiking Jun 11, 2013
  1. vwgtiking
    vwgtiking Active Member
    1,027
    To fit my double din head unit what do I require. Just a fascia?
  2. adamss24
    adamss24 Well-Known Member
    4,553
    393
    Ideally you will need just a fascia IF you have a symphony/double DIN as standard. If you have a single din then you will need the cage and also the climatronic...
  3. benjie
    benjie Well-Known Member
    1,223
    304
    As above, if you don't already have a double din unit in place, you will need to fit a double din cage - centre console needs to come out for this. The climate panel can either be replaced, or you can trim the edges of your current one.
  4. deano1978
    deano1978 different gear
    713
    80
  5. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,884
    182
    DD. cage is about £38 from tps not £100 +, used climate units are easily avalible or an even cheaper route is buy a knackard climate unit and trim the face plate to fit your good one depending what you inten to fit RNSE or aftermarket a facia surround will also be needed.
  6. deano1978
    713
    80
  7. vwgtiking
    1,027
    here is a pic of my oem stereo. So just need a fasia?
  8. vwgtiking
    1,027
  9. benjie
    1,223
    304
    You already have double din, so all of the above is irrelevent now.
    Just a new fascia and the correc wiring harness.
  10. vwgtiking
    1,027
    Ok. Can you point me in direction of the kit i require?
  11. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
