Double Din Conversion / RNS-D Retro Fit
g60leigh Jan 5, 2013
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    All done now. So here is the promised write up.
    Tools needed:
    T25 torx driver (short shaft is best)
    Torch
    Stereo release keys (4 if fitting a nav unit)
    Steps:
    1) Remove both side under dash panels by removing the two screws underneath and the screws behind the dash end trims.
    2) Remove old stereo and trim piece around hazard switch
    Slide out climate control unit.
    You will now see all the torx screws to be removed.
    3) Remove the 2 screws at the top, 4 on the front and also there are 2 on either side near the back of the trim.
    [​IMG] [​IMG]
    4) The trim will now pull forward allowing you to disconnect the electrical connections and remove.
    5) This will now reveal the inner cage which is held in my a screw either side.
    Remove the screws and the cage will lift out.
    [​IMG][​IMG]
    6)Run your GPS antennae connection to the rear if the stereo and locate the receiver end up into the dash cavity. As high up as you can so it has a clear as possible line up through the windscreen.
    If your also fitting TMC or TV tuner as well run the cables into the stereo area now.
    7) Now it's just a case of fitting new double din parts in reverse of the above.
    8) Once you have refitted all the dash panels you will be ready to install the nav unit.
    This is just a case of plugging in all the connections and sliding the unit in.
    One thing to note on the install is that the RNS-D required a 'safe' feed wire.
    This was simply a wire linked from the permanent live to the safe connection as shown on the wiring sticker
    On mine it was the red and white cable linked into the plug hole next to it.
    Notes:
    Don't tighten the new inner cage until you have lined up the outer trim.
    When fitting the outer trim locate the base first and it will go back in a lot easier.
    Finished result
    All in all it is not a difficult or long job.
    It's taken me about two hours and I have done that in the dark (only spare time I could get)
    To set up all the features of the nav unit you will need access to vcds to code it in.
    I will add a link to the coding info below.
    If you have any questions or would like extra help just let me know.
    Jay A3 likes this.
  2. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    25,697
    8,778
    Thanks Leigh, thread is now a sticky. :icon_thumright:x
  3. g60leigh
    1,674
    207
  4. chemicalboy
    chemicalboy New Member
    12
    Nice DIY man!!
    Can you tell me the exact model and manufacturer of the stereo to buy in ebay?
    Thanks!!
  5. g60leigh
    1,674
    207
    Mine is a RND-D. Audi A3 (8L) model so straight fit on the fascia side.
    My model number is 4D0 035 192 H
    I think any RNS-D will work but A4 & A6 ones etc need trimming to fit the dash. And your left with gaps at the top
    Easiest way is to hang on for A3 one.
  6. chemicalboy
    12
  7. x3f3x
    x3f3x New Member
    Hi all, today I buyed RNS-D 4D0 035 192 H, i read that great tutorial and I have some questions:
    First of all If I mount that RNS-D it will work with the DIS, my car is the A3 8L ReStyling From 2002 with CANBUS, or i need the TMC Tuner?
    And If I need the TMC module can you tell me the model number of the TMC that you used?
    Thank you for all and Sorry For my english.
  8. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    I wrote a quick guide for installing the RNS-E system in the 8L chassis so thought i would post it here as its very similar to the RNS-D system.
    Basic Guide to setting up RNSE in an Audi 8L
    Items needed :
    RNSE – Best from an audi B6/B7 A4 as these are the closest in size to the hole in the 8L dash. Please note in order to get the RNSE to fit properly you will need to trim it down a small bit on the sides towards the top and also on the bottom edge as you need to remove the chrome strip and then remove the excess plastic.
    Stereo removal keys x 4 : Best bought as a set along with the loom from Kufatec
    Fakra radio connector : to connect your radio aeriel to the RNSE again best from Kufatec
    GPS aeriel : bought as part of a bundle with loom from kufatec
    Loom : Kufatec will make a loom for your car after you let them know which stereo you had originally and what car you have and does it have bose or not.
    Wire to run from behind dash clocks to the loom for Can High Can Low and Gala speed sensor.
    Maps DVD – preferably an original as these work best.
    VCDS : to be able to code the RNSE unit so that it thinks its fitted to an a^ as this is the only way to get it to function in the 8L
    To Install :
    In order for the RNSE to function correctly 3 wires need to be run from behind the dash clocks (speedo rev counter etc).
    Remove the clocks and on the back you will see 3 connectors 1 green 1 blue and 1 grey. We need to connect a wire on Pin 31 on the blue connector and run that to the wire on your new kufatec loom that connects to the gala speed sensor in the RNSE. We then need to connect 2 more wires in the grey connector Pin 5 (Can High) and Pin 6 (Can Low) these then need to be run to the loom and connected to the same on the RNSE (please note the RNSE has a wiring guide on it to help you identify which wires these are.
    Whilst the dash clocks are removed this is a good location to install the GPS aeriel too and then you can run the wire to the RNSE the same as you had with the 3 wires you just made.
    The dash clocks can now be reconnected and fitted back in the dash
    At this point it might be a good idea to test the setup and code the RNSE so you can confirm everything works.
    Once you are happy that the unit functions correctly you can then trim the RNSE to the space you have in the 8L (take you time and remove small amounts at a time).
    Once it is trimmed you can push it into the cage and it should click into place.
    You should now see info displayed on your DIS screen giving SATNAV info and also radio/MP3 info.
  9. freple
    freple New Member
  10. Mi11ar
    Mi11ar Active Member
    316
    35
    Very impressive something to consider for the future
  11. Munch
    Munch Member
    256
    23
    Anyone know if this can be done on a pre facelift a3 8l? Looking to fit an aftermarket double din to mine, but can't find a definitive answer to what I need
  12. BenJee_S3
    BenJee_S3 Active Member
    153
    37
    I have the RNS-D installed, how the hell do you get it out? Is it same as above? Removal side panels etc or will it slide out with removal keys?
  13. g60leigh
    1,674
    207
    Two sets of removal keys needed (4 in total)
  14. BenJee_S3
    153
    37
    And where do they push in? There aren't any visible slots round the outside, although saying that it is pretty dark!
  15. BenJee_S3
    153
    37
    I have the keys also by the way :)
  16. BenJee_S3
    153
    37
    I have since found where they go, very well hidden I might add! Just above and below the buttons!
    g60leigh likes this.
  17. vrbob
    2,375
    171
    Just a quick update to my post as I spotted a few spelling mistakes etc
    Items needed :
    VCDS : to be able to code the RNSE unit so that it thinks its fitted to an a6 as this is the only way to get it to function in the 8L as we use the Gala speed sensor for the GPS info
    To Install :
    At this point it might be a good idea to test the setup and code the RNSE so you can confirm everything works. This is done in the Navigation section in VCDS and you have to recode the RNS-E (The code will be something like this : 0509135 the important bit is the 05 as that's the A6 part the rest is the config on your car.
    Once you are happy that the unit functions correctly you can then trim the RNSE to the space you have in the 8L (take your time and remove small amounts at a time).
    You should now see info displayed on your DIS screen giving SATNAV info when using the SATNAV function and also radio/MP3 info
    I still have a few PDF`s I gathered when doing this upgrade that go into more detail so if you want them you can PM me :)
  18. vrbob
    2,375
    171
    Some pics of the RNS-E fitted to my car
    On
    Off
    Display on the DIS screen
    daithi23 and Gops like this.
  19. S3_Olly
    S3_Olly Full Throttle
    268
    Anyone know where the photos have gone as I'm looking at doing this but would like to know and see what I'm doing rather than cocking it up lol
