Doubla din and air con
sherry Apr 25, 2008
  1. sherry
    sherry Member
    181
    Hi.
    Hope this isn't a silly question.
    Is it possible to fit a double din with sat nav and upgrade to air con in my a4?
    I have seen the sat nav, full air con system and the controls for sale on ebay.
    Cheers.
  2. Siena
    Siena Active Member
    2,626
    Has your car got aircon currently?
    I also have a facelift double din console, and RNS-E. If your car has aircon, you'll need to facelift the lot to get the RNS-D in there.
  3. sherry
    sherry Member
    181
    Hi Siena
    Thanks for the reply.
    It doesn't have air con.
  4. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Retrofitting aircon/climate is probably the biggest job in the world. It's not impossible but is a massive task. Far easier to sell the car and buy the one you should have bought in the first place.
  5. Siena
    Siena Active Member
    2,626
    Not an easy job.
    If you're not confident about doing the install yourself, PM me.
  6. sherry
    sherry Member
    181
    Thanks for the info guys.
    Does anyone know of a guide so i can get an idea of the work involved.
    Cheers.
  7. Siena
    Siena Active Member
    2,626
    I've never seen a guide to installing RNS-D and Climate Control.
  8. sherry
    sherry Member
    181
    Thanks again siena.
    Is it possible to install the double din without upgrading to air con?
  9. Siena
    Siena Active Member
    2,626
    ALL double-DIN cars had climate control as standard, so...?
  10. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,776
    33
    I was recently quoted over £400 to just fix a leak in my aircon compressor after a garage managed to **** it up during an engine pull.
    As Siena says, you're probably better off selling yours and buying one with aircon!
  11. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    quite fancy fitting facelift centre console in my wifes avant, and she said she preferes mine so thats as good as giving me permission, are the climate controls a straight swap
  12. olds_kool
    1,094
    15
  13. Broken Byzan
    13,237
    466
    I also think its a dash out job to swap the heater matrix part in and then lots of wiring.
    I double din'd mine, but i had aricon already so it was reasonably easy to do. The facelift aircon unit plugs straight in, just needs the addition of an illumination wire, Its the switches that give more problems as they require a silly little relay thing, to turn a momentary switch to a latch
  14. jcb
    jcb Active Member
    4,132
    13
    climate control is not just a "control" swap with the centre console.
    cars with two zone climate control have a different set of air ducts that are effectively two systems (so you can be in 30 deg heat while your passenger is in 18deg).
    not only a dash out job to fit those you will have to find them first.
    fitting the compressor and the aircon radiator will be another headache as the space is pretty tight in there.
    proper ball ache
    open the windows and get some Sure roll on
