Door wiring question
B5NUT Jul 6, 2011
  1. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,697
    642
    So before I get a new lock mechanism I wanted toi check the old one. Now what I cannot undersatnd is the wiring does not seem to be correct. On the micro switch side I have pins in position 1 - 2 - 3 but on the plug side I have pins 2 - 3 - 4 wired (with the wire colours stated below)
    Pin 2 - Brown
    Pin 3 - Brown/Yellow
    Pin 4 - Brown
    Been looking at elsawin and want to confirm I have the correct diagram
  2. B5NUT
    3,697
    642
    Never mind fixed the fault. The brown/yellow wire is connect via crimp connector to two other brown/yellow wires. The b/y wire going into door micro switch had snapped at the crimp with the other b/y wires, soldered up and it's all working. Still puzzled as to why the micro switch & the harness are out (pin wise) but it's working fine like that!
