Door trim removal
matt116 Sep 12, 2005
  1. matt116
    matt116 Member
    41
    Can any one help. I have a strange noise inside my door when i close it (a rattle noise) which I only hear whe outside the car. If i close the door when inside it shuts with a thunk but it is annoying when outside.
    I would like to have a look inside the door but i'm not sure how to remove the door trim. Any one help??
    May thanks
  2. god_thats_quick
    2,507
    simple,
    1. open door
    2. remove screw in grab handle and remove cover.
    3. remove two screws under handle and two screws at the top ends of the door.
    4. lift whole door card up from bottom.
    then if you want to actually remove the card from the door disconnect all the cables, I'm going to post a longer how too including this on another thread when I get chance as I said I would after changing my door latch.
    be careful to line up the lock thingy when putting the card back on.
  3. matt116
    matt116 Member
    41
    thanks for that but wheres the screw on the door grab handle?
    Thanks again
  4. god_thats_quick
    2,507
    at the back in the middle, you'll need quite a long cross head screwdriver to get at it easily then the cover drops down at the back and unclips at the front.
  5. Triple_A
    Triple_A Member
    100
  6. matt116
    matt116 Member
    41
    Brilliant, thanks for the assistance. /ubbthreads/images/graemlins/beerchug.gif
  7. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    It's easier with the window down, just ensure when refitting that you get the white plastic clippy bit over the metal under the window rubber, otherwise it won't sit properly.
  8. Markb
    Markb Active Member
    2,139
    This is how it will look once they have been removed:
  9. matt116
    matt116 Member
    41
    Thanks again for that. All sorted thanks all went back okay but I still have the problem with a squeaky window...any ideas?
    I have cleaned the rubbers, greased the runners in the door etc but it still makes the squeaky noise.
    I also have a problem before I removed the door trim I must add, the open door warning shows on the dash when I sometimes shut the drivers door. This means the interior lights are still on and I can't lock the car from inside. Any one know where the sensor is to check perhaps.
  10. god_thats_quick
    2,507
    Hi Markb,
    Just looking at your door, have you removed any of the other part of the door in that pic? just I'm sure my S3 has another impact bar going diagonally as it would appear the car in the pics higher up the page does...
    just my curiosity... /ubbthreads/images/graemlins/noidea.gif
  11. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    Hi Markb,
    [/ QUOTE ]
    No mate.
    If you look at the pictures in the instructions it appears to be the same as how mine is.
  12. Khufu
    Khufu Well-Known Member
    5,704
    31
    picture looks the same as my a3. The switch is in the door latching mechanism, some people have has some success cleaning it with WD40, others not. Have you tried back to black on the rubber parts to stop the squeak?
  13. god_thats_quick
    2,507
    I mean this one...
    Must be seeing things as I can't see that alu bar in the pic of your front door. /ubbthreads/images/graemlins/shutup.gif
  14. Markb
    Markb Active Member
    2,139
    [ QUOTE ]
    I mean this one...
    [/ QUOTE ]
    Maybe because the alu bar you refer to is the runner on the bottom of the window /ubbthreads/images/graemlins/laugh_roll.gif If you look my window is down and you can see it at the bottom. His must be up /ubbthreads/images/graemlins/tongue.gif
  15. god_thats_quick
    2,507
    As I just said in the other thread... I do have my blonde moments...
    In my defence I did have a whole bottle of wine when I finished so it's not a surprise it's a bit blured!
  16. matt116
    matt116 Member
    41
    Thanks for the advice, I shall gigve WD40 a go but as far as the window goes not sure what to do, I shall give it a go though. Thanks for the advice.
