Standard fronts are 4" mids and 1" tweeters. They're also mounted in a bizarre fashion with only 3 mounting posts offset from the aperture in the door card so you need adapter rings to mount anything in there (even an aftermarket 4" driver). Depth is the biggest problem as you only have about 60mm including the adapter rings.
