Door problem
Bradderz_1988 Feb 4, 2012
  1. Bradderz_1988
    3,946
    235
    The other day unlocked car and drivers door wouldn't open went through back door and opened with ease drove 12 miles or so to work and it worked fine when I tried it at work now this morning the passenger one did at the misses got a strop on as she thought I locked her out in the cold lol but again opened fine from the inside ??
    Is it just the cold weather that's freezing the lock or is it a problem beginning to start ?
    Any suggestions ??
  2. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    Are locking pumps air or electric driven?
    VCDS Scan? :D
  3. Bradderz_1988
    3,946
    235
    I would of thought air driven of the pump and electric side is just to let the comp no there's a fault or the doors are open for courtesy lights etc may be wrong though lol
  4. ScottD3
    15,161
    1,121
    I think the change over was about the FL time.
    PFL was air pump driven and FL was electric. I think.
    If yours is a PFL, it will be air. so you could have a leak or something freezying stopping it from opening.
    The VCDS will tell you if there is a fault with the pump, like if it ran on for to long which will indicate a air leak.
  5. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,094
    329
    His is 99 1.8TQS so facelift
  6. ScottD3
    15,161
    1,121
    With electric door locks, not the air kind.
    Can only think its cold and its effecting the motors.
  7. LeeT
    LeeT Member
    429
    Mines a 99 and still prefacelift :)
    I think you'll find all b5's have air driven locks. Its only the tailgate/boot of the facelift thats electric
  8. ScottD3
    15,161
    1,121
    Thats where i'm getting confused then.
    I thought FL went electric all round along with the boot.
  9. slepy
    2,094
    329
    But not TQS :angrymod:
  10. griswold
    griswold Member
    350
    mine 99 facelift tqs air locks
  11. ScottD3
    15,161
    1,121
    So its air locks.
    VCDS and check for a leak.
  12. aragorn
    18,135
    764
    You can tell if theres a leak by listening to the pump.
    If its fine it whirrs for a couple of seconds at most. If its leaking it'll whirr for ages, 10-15secs.
    If you dont fix it and it is a leak, you'll shatter the impeller in the pump.
  13. LeeT
    LeeT Member
    429
    well technically it is. Its turbo, its quattro and sport suspension :)
  14. aragorn
    18,135
    764
    All B5's have vacuum locking anyway.
  15. ScottD3
    15,161
    1,121
    Thank you.
    I will remember that. :)
  16. LeeT
    LeeT Member
    429
    There's an echo in here :)
  17. slepy
    2,094
    329
    So you have a quattro 1.8T pre-facelift? :think:
    EDIT: it's S4 isn't it? :w00t:
    LeeT likes this.
  18. andyw82
    andyw82 Member
    46
    it will be the central locking pump mine has been faulty since i brought mine, it a 2000 faclift, when i first striped the pump cause nothing work the impella was shattered, so i got 1 from the scrapy, and swaped the impella over as they are coded to car so would need vagcom or someting to install! so after the swap i got my door to work but none of the rest! my door was perfect for a few month now if i unlock it only half unlocks it but if i pull the handle a few times it opens! best bet is your local scrappy, as the ones on ebay i think r a little expensive, i paid 10 from scrapyard! there seem to be 2 vacum lines on mine think 1 is for drivers door and the other for the other 3! hopes this helps abit!
  19. ScottD3
    15,161
    1,121
    You can by impeller kits off Ebay.
    I'd buy one of them over a breaker unit.
  20. aragorn
    18,135
    764
    Buy a "4A0" pump from an Audi 80 or similar and swap the compressor from that. They're much sturdier.
  21. LeeT
    LeeT Member
    429
    No **** Sherlock :D
