Door open sign on dash
audi lover Feb 6, 2010
  1. audi lover
    audi lover New Member
    13
    My 52 plate A3 shows the Door Open sign on the dash most of the time.
    It seems to be the drivers door as the sign will go out occasionally, particularly when closing it when the weather's really cold
    When I lock the car, the doors will lock but the flashing diodes won't come on (guess this means that the alarm isn't setting as the sensors think a door is open?) - The courtesy lights in drivers door stay on and you can see them from the passenger side window
    How do I solve this?
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,246
    2,071
    common problem,I changed the mechanism to sort mine,you might find that you get three beeps from your alarm as well.
  3. audi lover
    13
    What, the lock mechanism - how much did it set you back?
    cheers
  4. Westy
    Westy Well-Known Member
    17,443
    1,105
    Door lock is about £100 fitted. Its not too dificult to fit yourself though.
  5. dancarpy
    dancarpy S3 DCY
    236
  6. voorhees
    16,246
    2,071
    Bloody hell !! I got mine off a member on here 12 quid and Audi fitted it for nowt as they said it was a warranty issue.
  7. audi lover
    13
    Nice one - that link is spot on. Gonna give that a go
  8. Westy
    17,443
    1,105
    I've been mugged!
    I have since stripped the doors down a few times and would now be able to fit a new door lock by myself.
  9. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Check out what dancarpy posted. I had this problem also when i got my car last year. All sorted now after fiddling with the switch thing in the door!
    It used to happen again after a few days on and off but i was also advised to use the following to give it a nice clean. Ever since i sprayed it inside where the switch is, my door has been perfect with no problems! :)
    Link:
    http://buy.maplin.co.uk/Module.aspx?ModuleNo=4153&DOY=6m2
    If you go into Maplins, you don't have to get that pricey one, just get the Maplins own brand one which is what i got. The can is white with a green line border around the label of it. (just thought i'd mention that as they've changed the design of the cans lol)
    Jay
  10. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Don't feel to bad mate I paid the same to have my drivers door lock replaced!
  11. cabby86
    cabby86 Member
    My S3 had the same problem, but it only occurred when the weather was warm. Had mine fixed by Audi under warranty, but when the stealer called me up to let me know the diagnosis, they forgot it was a warranty job and quoted something like £226 to fix it!!!!! So £100 does sound cheap in comparison!!
    Chris
  12. MIKE GTR
    MIKE GTR Member
    366
    I wouldn't worry, the only problem that can arise is that the light on the bottom of the door stays on and can run your battery down if left for a few days
