Door movement on rough(ish) roads.
hiltoa Jun 10, 2007
  1. hiltoa
    hiltoa VAG erfahren
    298
    Has anyone noticed movement from the door when driving on less than perfect roads?
    I can hear the door moving about on it's seal, as though the chassis is flexing.
    Is this common, or do I have a knacked door / car! :faint:
    Thanks, Al.
  2. macca
    macca Member
    525
    my drivers door does the same, and knowing the car since new, i know it hasn't been in a prang, so i was wondering if it is hinge wear or misallignment of lock/shut catch.
    be interested if someone knows a cure.
  3. hiltoa
    hiltoa VAG erfahren
    298
    Phew, not just mine then! :)
  4. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    All doors move when the car is in motion, if you want to check another car, just put your fingers up between the rubber and door at the top and have a feel while the car is moving. If you can hear it then clean the rubber thoroughly with soap and water, then give it a spray with silicone lubricant/polish then it'll be quiet.
  5. dsmclark40v
    dsmclark40v Member
    744
    Mine does it all the time too, but only on the drivers door. mine also has alot of wind noise at high speeds. I know i need to adjust the top half of the door to stop that but i have been a bit lazy lately and haven't got round to sorting it
  6. macattax
    macattax Member
    455
    How do you adjust top half of door then and will it get rid of wind noise?
  7. dsmclark40v
    dsmclark40v Member
    744
    there was a thread about it a couple of months back. you have to take the door card off (which is why i haven't done it yet) and then there is a bolt you have to loosen and then just move the top of the door in a mm or two and then tighten the bolt back up and then it should get rid of the wind noise. see here http://www.audi-sport.net/vb/showthread.php?t=35696
  8. Lowlife
    Lowlife German Hardcore
    568
    Sounds like you have the same problem as me, does your door move up slightly when you shut the door? If it does its dropped a bit over time, there was a thread a while ago on how to fix it, have a look.
  9. hiltoa
    hiltoa VAG erfahren
    298
    Thanks for the responses guys - I'll have a closer look when this chuffin rain stops!
  10. Turbo Lag FTW
    Turbo Lag FTW Hate those none insured you know who types
    235
    Hmmm was wondering why my drivers door doesnt shut well, didnt think the door had dropped, yet another to do on my list.
  11. ZeroK66
    ZeroK66 Member
    256
    i used to get a horrible squeeking from my doors cause of this. Some wd40 on the rubbers sorted this :p Guess it si normal
