  1. floyd 1.8 turbo
    floyd 1.8 turbo Mirror, Signal, Outmanoeuvre
    632
    Do the door mirrors come apart? I want to remove the cover and glass from the base plate
    Any advice welcome! Thanks
  2. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    two little screws hold bottom plate on (while its off drill a couple off little holes in it this helps water escape when you wash car but you wont be able to see them when refitted)
    glass clips in place you have to carefully prise at the edge, it will pop out
    this will then reveal 3 screws that hold cover on, then a biy of a twist + wiggle to remove it
