My drivers door will not lock when I use the remote, it locks everything else apart from that. But it works when I use the key. Any ideas what's the problem??????
I discovered last night that mine is doing the same thing!!! The remote locks/unlocks all the other doors but the driver's one can only be locked and/or unlocked by using the key in the lock.
I'm hoping some WD-40 to somewhere readily accessible will do the trick but not holding my breath...
I have this too, and now it's also happening on the passenger side as well. The passenger lock is more painful as I have to use the key and push it into a slot when the door is opened. I must check wiring looms before I go and buy new locks.
