The symptoms I have are that the drivers door and rear off side door dont work the lights .
I have run a scan using VCDS LIte and I got the following errors from the central locking:
Address 35: Centr. Locks Labels: 4B0-962-258.LBL
Controller: 4B0 962 258 K
Component: Zentralverrieg.,DWA D35
Coding: 06859
Shop #: WSC 02325
VCID: 311541C4E831
11 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01559 - Drivers Door
58-10 - Can't Lock - Intermittent
01561 - Left Rear Door
59-10 - Can't Unlock - Intermittent
01562 - Right Rear Door
59-00 - Can't Unlock
60-10 - Won't Safe - Intermittent
61-00 - Won't De-Safe
01134 - Alarm Horn (H12)
49-10 - No Communications - Intermittent
I have cleared the error messages but I still have the problems of both off side doors not switchin on puddles lights/interior lights or registering on the central display.
Is it possible that both door lock micro switches have failed , or should I start with the CCM in the passenger footwell?
Is there a way of testing the lock modules using VCDS
Coding: 06859
Shop #: WSC 02325
VCID: 311541C4E831
11 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
