Door has drop now.won't open?
dancupra225 Mar 29, 2013
  1. dancupra225
    dancupra225 Active Member
    667
    25
    I have a Audi a3 2004 plate 2.0 tdi
    And the door has dropped so was going to sort it today but now the door.won't open now catch won't open it nothing
    Anyone know of anyway to open a door without a catch cant get door card off well only a little bit
    Help
  2. dancupra225
    667
    25
    Thought Audi have presure locks or something ??
  3. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    It should still open with a tug?
  4. dancupra225
    667
    25
    No proper Shut handle.cable i think is not connected really stuck
  5. Geraldy212
    Geraldy212 Sportback owner
    565
    41
    Wind down the window. Get two strong persons outside of the car to reach inside and grab whatever they can and lift the door. Someone inside then operates the door release handle and gives it a big shove. That just might shift it. Good luck.
  6. dancupra225
    667
    25
    Tried that no cable works on handle so im stuck what to do
  7. Geraldy212
    565
    41
    What about the outside handle? Does that work at all?
  8. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    Strange both the inside and out side shouldnt fail togeather
    unless the lock is jammed somehow
  9. dancupra225
    667
    25
    Yeah both have stop working just you can feel it trying to work but think.the lock is jammed up
    So anyone got any thoughts how to open the door, crowbar or bar cloth protecting the paint
  10. dancupra225
    667
    25
    Anyone?
  11. Geraldy212
    565
    41
    Take it to a body shop nearby. They will have more special tools, including bodywork clamps that they can fasten to the door itself. If it needs a crowbar, they are the best people to do it to avoid a lot of damage. Another idea is to try to get some WD40 into the lock mechanism. Either through the key hole, or down through the window guides (with window down), or if you can pull the door card a bit, and squirt in there.
