Door closing problem
Boydie Mar 15, 2009
  1. Boydie
    Boydie Boycie VCDS Map User
    3,327
    423
    Guys,
    Hopefully you can help here
    My drivers door sometimes will not close properly to which I think is a mechanism fault with the lock
    When I go to close the door, it clunks off the latch and wont close. What I have to do is pull the outside handle again and then it usually closes but not all the time :(
    Anyone experienced a similar problem?
    Do I have to replace the lock?
    Thanks!
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    sounds like its the latch. I'd spray WD40 into the latch part and work it back and forward and see if it free's off, if not you could be looking at a new one.
  3. davemk
    davemk Active Member
    459
    34
    As above, I'd use some WD40 onto the latch area and try and clean it out.
  4. Boydie
    3,327
    423
    cheers lads - will giv it a go!! :)
