  1. Phantom_A4
    Phantom_A4 Member
    563
    Just trying to remove my door cards to change the speakers, with no success. Have taken off 3 screws, two at the top by the window and one in the handle. Anyone know what im doing wrong, or if im trying to remove it with more screws attached still /ubbthreads/images/graemlins/frown.gif
  2. madkebab
    madkebab Member
    421
    once you have taken the one off in the handle remove that piece of trim by pulling down and that will reveal two more screws if I remember correctly.
  3. docurley
    4,072
    87
    Then lift the door card up to remove
  4. docurley
    4,072
    87
    Remove the two visible screws at the upper corners of the door panel. Remove the screw that's visible inside the oval-shaped hand grip area in the arm rest. This screw holds the oval piece in place that trims the oval cutout in the armrest that forms the hand grip. Remove this trim piece by snapping it out downwards; this will expose the final two screws that need to be removed. The door panel will lift straight up then out at this point. You'll have to disconnect electrical connectors (speakers, power windows, etc). You'll have to disconnect the door latch cable... this hooks into the inside door handle, the cable end has a shepherd's hook (question-mark-shaped hook) that you'll need to unhook. Then, just lift the panel up high enough so that the door lock pin is cleared, and you're free.
    The door frame has a number of small cutouts, into which L-shaped hooks in the door panel slide. These cutouts have rubber pieces lining them, to keep rattles down. When you remove the door panel, keep an eye out for rubber pieces that have come out of these cutouts; it's easy to knock them out and then forget to put them back in.
  5. Phantom_A4
    Phantom_A4 Member
    563
    Thanks guys, really appreciate that. Anyone have their door speakers free, one has a hole in it lol!
  6. madkebab
    madkebab Member
    421
    I think I have my old front ones if you need a replacement. They were non Bose though
  7. Phantom_A4
    Phantom_A4 Member
    563
    Mine are the standard blaupunkt ones, just attemtping to use my old shelf speakers in the doors. Will let you know though dude /ubbthreads/images/graemlins/smile.gif
  8. madkebab
    madkebab Member
    421
    think you'll find they are a different size.
  9. docurley
    4,072
    87
    I will be swapping out my Bose speaker with a Pioneer mids and tweeters so you can have them when they are out. Just waiting on the speaker adapters.
  10. Phantom_A4
    Phantom_A4 Member
    563
    Yea just made some small custom mdf pods, to home the shelf speakers in the door. Thought the window would hit on the way down but didnt. Really pleased. Keep me posted on your speakers, might have to nab them off you /ubbthreads/images/graemlins/laugh.gif
  11. rs13219
    rs13219 Member
    114
    If phantom doesn't have them could i have second refusal please?
