door blades
jbh Aug 8, 2013
  1. jbh
    jbh TDi lover
    1,412
    168
    As the title suggests I'm looking for blades along the bottom.
    I'm needing the ones for the wings and one for the rear drivers arch.
    Can any one help me out or will I need to go hunting the local breakers?
    Cheers James
  2. Bradderz_1988
    3,987
    261
  3. Bradderz_1988
    3,987
    261
    Why not go S4 trims and skirts ??
    jump over to audi srs see if any ones breaking one infact i think micheal1001 iirc has a breaking hes having the front end off !!!
  4. jbh
    jbh TDi lover
    1,412
    168
    Yea but I don't see the expense in buying a full set when I'm only needing 3 plus ifs the small ones.
  5. jbh
    jbh TDi lover
    1,412
    168
    ah now you say that!!! It might be s4 ones I'm fitting as they came off jcb's car plus I have his skirts.
    any pictures of the difference? as im starting to think it is whats on the doors im fitting. plus I have one of the rear arch ones and it looks as if it mounts with the skirts
  6. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    If there is a skit, I think it will be S4 ones and I got a feeling his was S4.
    If they are not, I would recommend buying a set of new ones and new wing bits cause the colour difference between old and new would be noticeable.
  7. jbh
    jbh TDi lover
    1,412
    168
    yea looking at them Scott there come out far at the bottom so im pretty sure there S4 ones.
    there colour coded to the car
  8. Broonie
    Broonie Active Member
    166
    42
    They are s4 ones, I was eying them up when I was down getting the engine but Ed said they were already paid for
    i need some for mine as I don't like the black strip between the door and votex skirt
  9. jbh
    jbh TDi lover
    1,412
    168
    yea I was sure they were but to be honest before I had a look at ones on the bay I thought all the difference was they were colour coded :tocktock:
  10. Bradderz_1988
    3,987
    261
    S4 mouldings have separate backings that the painted bit clips on too and they also overhang on the doors there hard to get individually, i no i bought just the 4 door pieces only 2 had backings and for double what i paid for them i got the full set with skirts posted !! Your best off getting the full set otherwise you will end up paying over the odds ive only ever seen the wing/arch trims on ebay.us and there like £30 each plus post etc !!
  11. jbh
    jbh TDi lover
    1,412
    168
    any one got a part number for them?
  12. Bradderz_1988
    3,987
    261
    Part listing:
    (1) 8D0-853-859-GRU trim
    (1) 8D0-853-860-GRU trim
    (1) 8D0-853-923-01C holder
    (1) 8D0-853-924-01C holder
    (10) 8D0-854-955-B-01C-GRU ring
    (10) 8A0-854-953 cover
    (1) 8D0-853-941 strip
    (1) 8D0-853-942 strip
    (1) 8D0-854-973 clamp
    (1) 8D0-854-974 clamp
    (1) 8D0-854-977 clamp
    (1) 8D0-854-978 clamp
    (1) 8D0-854-983 clamp
    (1) 8D0-854-984 clamp
    (1) 8D0-853-959-A-GRU moulding
    (1) 8D0-853-960-A-GRU moulding
    (1) 8D0-853-969-A-GRU moulding
    (1) 8D0-853-970-A-GRU moulding
    (1) 8D0-853-953-B-GRU moulding
    (1) 8D0-853-954-B-GRU moulding
    (1) 8D0-853-963-B-GRU moulding
    (1) 8D0-853-964-B-GRU moulding
    (1) 8D0-853-974-B-GRU moulding
    (1) 8D0-854-861-A-GRU cover
    (1) 8D0-854-862-A-GRU cover
    thats everything now just to narrow them down lol
    jbh likes this.
  13. jbh
    jbh TDi lover
    1,412
    168
    cheers bud.. I just need to spend time on google now to work out which is the 3 I need
  14. jcb
    jcb Active Member
    4,132
    13
    What you missing?
    mid door
    lower door or
    sill?
    should all be there unless there is something still on the rear arch.
    will have a look later today
  15. jbh
    jbh TDi lover
    1,412
    168
    Hi Ed its the sections for lower door it's the drivers rear arch and the 2 front wings sections.
    if you can find them it would be great if not its not a problem mate :icon_thumright:
