Door blade removal tips
S3MVR Oct 31, 2011
  1. S3MVR
    S3MVR Member
    Hi all,
    I've got a replacement passenger door blade for my s3 but i can't find any info on removal or refiiting.
    Anyone got any tips or know of any links to some info.
    Cheers!
  2. jojo
    28,997
    3,649
    4 screws mate, one at the front and one at the back of the door. There's 2 more under 2 rubber grommets under the door card, make sure you have a magnetic screwdriver, cos if you drop them, it's door card off time! Once you remoce the screw, the door blade just slides backward by an ince or so and pulls off!
    I highly recommend you get some new screw from Audi, they are 26p each(they was 6 years ago!) I think?
  3. Hadders
    Hadders Member
    134
    Out of interest Jojo, why do you suggest new screws? I'm planning on having my trims off soon so I can repaint them (meant to do it already. Typically)
  4. jojo
    28,997
    3,649
    Because they are tiny, and you will probably ruin the old ones whilst taking them off, the new ones are only pennies and look galvanised compared to the original ones I had.
  5. feck_on_a_stick
    feck_on_a_stick Active Member Team Nogaro Blue
    191
    66
    Bringing this one back to the top. I'm trying to get the passenger side rear door blade off and can only find tips for the one on the door.
    From what I can gather it's just a matter of:
    - open passenger door
    - slide rear door blade left towards the open.
    I've tried this and it's not playing ball so before I go all out and but a bit of force into it, I just wanted to double check that this is correct. Obviously I don't want to break anything that's supposed to remain on the car lol
    Any pics of what's left on the car once it's removed would be great.
  6. The Doctor
    The Doctor Well-Known Member
    1,394
    189
  7. feck_on_a_stick
    191
    66
    Thanks for the link and read it before but from what I can see its only for the blade on the door itself. Im trying to remove the one on the quarter panel :)
  8. G60DAN
    G60DAN Member
    383
    Open door and pull it towards the front and it just comes off well mine did.
  9. s3mad_dude
    s3mad_dude Noggies ruuuule!
    619
    79
    Yep it just slides out....put a cloth over the end and gently tap the blade with a rubber mallet and it will soon loosen off.
  10. The Doctor
    1,394
    189
    So the blades on the rear quarter panels just attach to pins (ie no screws)? Presumably therefore re-fitting is just the reverse of removal, right?
  11. s3mad_dude
    619
    79
    No pins...a runner is built into the car and it just slides completely off the entire way. The door needs to be fully open.
