Don't ignore the signs (control arm content)...
mixmaster Jun 23, 2012
  1. mixmaster
    mixmaster Member
    86
    I'm Lucky. I was going slow. It wasn't noisy consistently and although I had a vibration under braking hard I was convinced it was the opposite side...
    So my lower rear control arm now looks like this:
    Uploaded with ImageShack.us
    Looks like the 20 hairpin commute has finally taken its toll.
  2. adidasandy
    adidasandy Member
    271
    Ouch, lucky lad.
  3. Bradderz_1988
    3,956
    238
    Yep same happened on my brothers last month wot a twat it completely siezed then snapped the control arm and ended up under the tyre so had to jack the car and get it in the workshop doing a 20 point turn to get it lined up on the ramp lol, i need to order a meyle kit for mine too as getting some vibration at high speeds when braking you may have just depleted my funds some more with that image lol
  4. mixmaster
    mixmaster Member
    86
    Is this an easy repair on a trolley jack?
    I'm debating the kit (they are only £300 from Germany ATM) but need to get it back rolling again quickly.
  5. Bradderz_1988
    3,956
    238
    Id say you could do it on a trolley jack with a axle stand to support the weight as you will/may be fighting with the bolts/nuts so a axle stand will be best but yeah its pretty straight forward you will have to drop the subframe a tad to get the rear bolt out other than that that just one nut and a nut and bolt.
  6. PAULF
    PAULF Active Member VCDS Map User
    712
    66
  7. adidasandy
    adidasandy Member
    271
    I've just done mine last week on the floor with axle stands no worries.
  8. gedi
    gedi Member
    59
    I did complete front suspension change on mine with jacks ant axle stands and its quite easy jobs just u need to loosen subrame bolst to remove the back arm bolts.the only thing when tightening arm bolts at the rubber part u have to make sure that the arms are leveled as if the front of the car is on the road cause otherwise u gona damage the bushings in the susp arm
  9. mixmaster
    mixmaster Member
    86
    Thanks for the replies. May have to get this one towed much to my frustration and pay and overpriced French garage...
    Would anyone be so kind to look up the OE part number? Thanks
    (It's the Drivers side lower rear arm)
  10. gedi
    gedi Member
    59
    4D0407694AC thats one of the part numbers
  11. adidasandy
    adidasandy Member
    271
    Is it your drivers side or ours? as I notice your in france.
  12. mixmaster
    mixmaster Member
    86
    Sorry it's a UK car. So drivers (Right Hand Drive) lower rear arm.
  13. mixmaster
    mixmaster Member
    86
    I think I going to attempt to replace the arm (from a full kit) in situ for now so I can get the car home to sort the rest.
    One problem, apparently is moving it as it's a Quattro so will need a flatbed.
    Can anyone advise on the lowering the subframe part? I have read a few articles but unsure of where to support the car. Some articles also advise not using the same subframe bolts again?
  14. Sulli79
    Sulli79 Active Member
    541
    37
    How far does it need to be moved, you can do it as long as it has all 4 wheels on the floor, but there is a recomended distance and speed which I cant remember!
  15. HEKTOR
    HEKTOR Member
    401
    Max distance it can be towed is 30 miles/50 kilometers
    Max speed it can be towed is 30mph/50kph
  16. aragorn
    18,434
    844
    If all four wheels are on the ground (ie towing with a rope, or bar) you can tow it as far as you like and as fast as you like. As far as the gearbox is concerned thats no different to being driven along the road.
    The 30miles/30mph limit is for towing with one axle lifted, such as on a towing dolly, or lifted onto the back of an AA van or similar.
    To get the bolt out, you only have to unbolt that one corner of the subframe. Easiest thing to do is jack the car and put the axle stand on the sill next to the jacking point. That gives you plenty of room to drop the subframe bolt and the triangular plate out.
    Once removed, you'll need to lever the subframe down a bit, a long piece of wood works best for this, as it minimises damage to the metalwork.
    When reassembling, fit the bolt the other way round, this ensures its easy to get at in future!
  17. mixmaster
    mixmaster Member
    86
    Thanks everyone.
    Just a heads up that a broken lower rear makes it pretty hard to tow either way as the wheel can hit the bodywork; In this case the wonderful ADAC took it on a flatbed to a local independent.
    One reason for this is I can have everything checked to see if it needs a kit as the tops are only a year old. I would hate to think what would have happened at 60mph+ if it went.
    Now I just need to see what they want to sting me for it...
  18. mixmaster
    mixmaster Member
    86
    Does anyone know if the Febi-Bilstein kits come with solid tie-rods like the Meyle HD kit? With the exchange rate at the moment the kit works out just over £280!
    Febi-Bilstein Kit or the Meyle HD kit
  19. dubster67
    dubster67 Member
    152
    9
    I got the Meyle HD kit off tierod69 on Ebay.co.uk for £338.00. Don't have the link, but just type in Audi and Meyle. BTW the Meyle HD kit has a 4 year guarantee. Worth it IMO.
  20. mixmaster
    mixmaster Member
    86
    Just to say I have had a full 'Moog' kit fitted and Geometry corrected on all 4 corners. Seems to be great.
    Watch this space to how long it all lasts!
