Doing first DIY oil change. WOOOOOOAH!
JJ.Foulds Apr 15, 2014
  1. JJ.Foulds
    JJ.Foulds Well-Known Member
    1,263
    176
    So im going to do my first ever oil change! WOOOOAHHHH.
    Im sure this is a standard thing to most but im ready for it!
    Iv watched this video, and im just wondering if theres any tips or tricks to doing this smoothy or to watch out for.
    iv got a socket set and torx so all should be good!
    https://www.youtube.com/watch?v=Pp6yFmzwhEU
    Thanks guys.
  2. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Video covers it all.
    Have loads newspapers down to capture any spills.
    Ensure oil is warm.
    Only nip up the sump plug. New copper washer not needed.
  3. Tom5190
    Tom5190 Active Member
    318
    139
    43
    Just done mine tonight after work, takes all of 15 min's really.
    The only thing that he doesn't mention is that you need to check the final oil level when the car is on the ground not with the front raised. Do as it states stick 4.5 L in, run the car then top up when the car is on the floor.
  4. JJ.Foulds
    1,263
    176
    so i should run the car to what temp before emptying? a normal 90?
  5. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    If you are using a multi-viscosity oil, such as 10W40 for example, this indicates that the oil is more liquid at cold temperatures than it would be at the normal engine temperature of 90. I believe that it is then better to drain the old oil when it is cold, rather then when it is hot. Anyway, that is what I do. Some folk use a flushing (low viscosity) oil to clean out the engine before putting in the new. Have not tried this so far. Good luck.
  6. wuta3
    wuta3 Well-Known Member
    1,131
    347
    Also, if you are changing oil filter, prepare for tons of oil to pour out even though you drained the sump.
  7. Tom5190
    318
    139
    43
    10w40 means the oil is thickest when cold.
  8. c_w
    c_w Well-Known Member
    1,169
    91
    Definitely change the oil when it's warm, it doesn't flow as easily when cold, although I have done an oil change before with cold oil (on the assumption that as the engine has stood the oil has fully drained to the bottom) but it just didn't drain half as well out of the sump.
  9. JJ.Foulds
    1,263
    176
    Shud i give it a good drive beforehand? or just run on idle?
  10. MrLapou
    1,233
    121
    Idle will be just fine. 5 mins. Then leave for a few mins so oil can settle.
    If doing it on a drive or porous surface be sure to cover all areas with plastic sheet or 2 layers newspapers.
