DOH - posted a pen through my vent?
richjohnhughes Mar 31, 2008
  1. richjohnhughes
    richjohnhughes Member
    104
    no laughing please - some how i have managed to drop a pen down on of the vents on the dash board..............and its rattling like mad.
    is it possible to remove the front of the vent to get it out?
    any ideas??
    :uhm:
  2. Kontraband
    Kontraband Active Member
    2,000
    ok... how did you do that??
  3. richjohnhughes
    104
    er,...............was talking on the phone and was trying to us it as a pen holder! doooooooooooh!
  4. Kontraband
    2,000
    hahahahahah ... Doooooh indeed!
  5. davemk
    davemk Active Member
    463
    37
    Sorry to laugh at your misfortune but that's very funny.......
  6. richjohnhughes
    104
    i know - its a laugh a minute, eh!
    but any idea how to remove it?
  7. PNH80
    PNH80 Low life livin' the high life.
    1,633
    Well...can you see the pen? I know you can remove the vent rings because they can be swapped (true?) so if you can see the pen i'd assume you could grab it with some kitchen tongues or similar? I'm just guessing here. Funny story though!
  8. The911SC
    The911SC Active Member
    1,032
    LOL (sorry) but that is funny!...
  9. Kontraband
    2,000
    I guess it depends how far down the vent its gone??
    You can swap the plastic for ally trim on the vents I think but I dunno if you can fully remove the vent housing?? I'd guess you can... someone must have done it??
  10. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    Usually a vent fascia will come off, but if its slipped back into the venting pipe you will have to remove the under dash tray (usually on VAG these are kept in place with star key / Torq screw things), and then from underneath you can unclip the hose ducting, but this will not be easy as its located quite high up in the dash. You may be able to take the end cap off the dash (this should prize off with a flat blade screwdriver if its anything like other VAG cars), but in some cars you may have to remove fuse boxes etc to get in at the side.
    THere is no easy way. What a bummer.
  11. richjohnhughes
    104
    thanks for the replies people
    grrrrrrrr- what a nightmare.
    apart from the rattle - is there any risk of damage if i leave it there?
  12. Twizzler
    Twizzler Active Member
    481
    32
    I'd go fishing for that with a piece of thin rigid wire bent into a small hook shape at the end. The vents are sure to come off. I've had the ones on the top of the dash out when I installed my Roadpilot pro. They prise out with a couple of small screwdrivers. If the pen has a pocket clip you may be able to hook it out. If it doesn't then slightly thicker wire bent over may be able to be manoeuvered past it so it can be slowly withdrawn. Sounds good fun.
  13. L60N
    L60N Guest
    Push a few more in to qwell the rattling.:lmfao:
  14. JimmyJames
    JimmyJames Jas.
    204
    Send in a note pad. I'm sure it will write itself. :lmfao:
  15. davemk
    463
    37
    :lmfao:......excellent!!
    On a more helpful note, if the pen was metal, how about using a magnet on a string?
  16. mattandrew
    mattandrew Member VCDS Map User
    977
    21
    Which vent did it go bobslaying down???
    Someone on here will be able to post a workshop manual page showing how to remove the pipe etc.
    Its more than likely to have gone out of reach, you may be lucky it may be easy to get to
  17. scott_johnson
    scott_johnson Audiless
    876
    What pen was it??? if its got metal on it you can buy telescopic magnets from most diy shops!!! or if your local i can lend u 1.....
  18. Boydie
    Boydie Guest
    Try get the vent off then put a tube down the vent from a vacuum cleaner or another attachement?
  19. tracieburr
    tracieburr Newbie in Poole
    23
    How about trying to suck it up with the vacuum cleaner hose
  20. mitch78
    mitch78 Active Member
    2,350
    :thumbsup:
  21. bacardi
    bacardi Active Member
    1,139
    if its one of the centre vents I'm sure I've seen the business end of these when I took the Head unit out, perhaps you could look behind there?
  22. mattfinn
    mattfinn Smoking is good for you
    833
    Centre vents just pull out dont they?
    I have to at this point confess to trying to remove some parking tickets that had found their way inbetween my windscreen and dash with one hand, and getting my hand stuck, so in a moment of clarity I tried using the free hand, which in turn got stuck! So im there, in rush hour traffic, with all 7 of my fingers (i'm one down, see nasty Injury thread) wedged in my dash lol! The car behind was NOT happy!
  23. richjohnhughes
    104
    - thanks guys.
    its gone down one of the centre ones - just had a look with a tourch and it not to be seen.......must have dropped right down??!!! eek!
    i think if the front of the vent can be taken off - i'll be able to get in there some how?
  24. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    554
    I thought the vents were one piece i.e. you cannot take just the front off.
    I looked into changing the black knurled bit for the alloy ones you get on the S3 a while back and most replies said it cannot be done unless I was to buy the the complete unit.
    However the whole unit should come out fairly easy. Seem to remember a post about someone who'd changed their vents for TT style ones and had done a write up about removal etc. only problem is I can't remember where I saw it.
  25. Twizzler
    481
    32
    You may be correct, but I'd have thought it would be a very unusual and complicated manufacturing process to do that. Things like this are normally made in multiple pieces and fitted together. They may have been glued together of course but the top vents on the dash aren't.
  26. mattandrew
    977
    21
    Had a look in the manual and heres what i came up with
    Ignore the special tool, use a screwdriver but DONT slip or you will have more than a rattle
  27. Twizzler
    481
    32
    Yep, just as I thought. Thanks Matt.
  28. L60N
    L60N Guest
    If it went down the centre one can you pull out your stereo and get to it that way?
    Regards
  29. richjohnhughes
    104
    great - thanks for that!! will have a go this afternoon and report back!!:think:
  30. consilio
    consilio Up the owls!
    666
    what colour pen was it? :lmfao:
  31. richjohnhughes
    104
    haha - a blue bic biro!
  32. Kontraband
    2,000
    damn all the effort youre having to put in for a fricking biro! ;)
  33. davemk
    463
    37
    A biro? You cheapskate! If you'd bought a proper pen, you could have used the magnet trick! ;)
    How about wrapping some duct tape around some wire or something similar and see if you can pick it up using that....bit of a long shot though.
  34. richjohnhughes
    104
    ha - spent all the money onthe car!!
  35. richjohnhughes
    104
    quick update -
    got the vents off no problem (thanks mattandrew) but the pen is no where to be seen - must have dropped right down into where ever it goes. eek!! might just get audi to have a look next time its in with them.
    cheers guys
  36. prt57
    prt57 Active Member
    768
    232
    43
    If you have a mate that works at the hospital you could be in luck
    If you could get hold of a gastroscope you could have a look down the hole, some of them have a little nipper on the end used to take samples for biopsy purposes. You might be able to grab hold of the pen.
    Only thing to watch out for is that it was well washed before you usue it!!
    prt
