Dogbone mount
ben_harmer32 Jan 23, 2014
  1. ben_harmer32
    ben_harmer32 Member
    111
    Went to the garage today to have my dogbone mount changed as there's a bang/clunk when I change gears. Garage started to do it but when undoing the middle bolt it started leaking gearbox oil.
    is this normal?
    Garage said aid they would ony do it if they fully drained the gearbox first, so gave up for the day and left.
  2. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Not at all, it's got nothing to do with the gearbox oil. I can't see why that is happening from a dogbone change.
  3. <tuffty/>
    21,897
    4,205
    Nopes... its not normal...
  4. Wallm0nkey
    Wallm0nkey Member
    225
    That is very odd it's a 15 minute job if it's on ramps!
  5. ben_harmer32
    ben_harmer32 Member
    111
    Fluid was dripping out when undoing the middle bolt. Is it possible if the gearbox oil was spilt when filling it might of collected behind somehow?
  6. <tuffty/>
    21,897
    4,205
    Had to check as this was niggling me... the dog bone bolts to the bell housing not anywhere near the internals of the box... the oil is not coming from there...
    Here is one I did earlier
  7. ben_harmer32
    ben_harmer32 Member
    111
    Very odd then, time to go to audi i guess....
    Just so we are clear it's this bolt that is leaking:
  8. vanilla_ice
    vanilla_ice Active Member
    717
    Sorry, small hijack. tuffty, is that purple bush the powerflex one? If so, could you say whether that bush in particular emphasises cabin vibrations? Going to fit the red (in your case yellow) bush, but in two minds over the purple bush. Any experience with the superpro equivalent?
    <hijack/>
  9. newbster
    newbster Active Member
    302
    71
    oh dear, not good
    just checked on my spare box, that bolt hole goes all the way through the bell houisng, so any fluid collecting in there will come out when you undo
    it could be two things
    gearbox oil, leaky input shaft seal in gearbox
    engine oil, leaky rear main seal
    both are gearbox out jobbies and possible new clutch plate
  10. stoog
    stoog New Member
    Kind of related where youve highlighted the bolt for dogbone bush mines cracked on gearbox any1 know if any ways to sort this or is it as simple as new gearbox
