dogbone front bush
karl210 Nov 20, 2012
  1. karl210
    karl210 Member
    324
  2. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
  3. karl210
    karl210 Member
    324
    cheers but they are the rear of the dogbone, i need the bush at the front that goes onto the engine, not the chassis if you get me
  4. Alex C
    3,297
    373
  5. karl210
    karl210 Member
    324
    yeah the small one on the left of that pic cheers, £37 though! oouuchh. Ive seen a brand new dogbone with bushes in for £22 that might be the easier route, i was only expecting to spend about £20
  6. Alex C
    3,297
    373
    yeah i was only trying understand which one you meant, that one does seem a little steep
  7. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Not much requirement for that IMHO. The bush goes into the gearbox yes - but there is the piece of metal connecting the second bolt. This means there isn't much give in that bush anyway - hence the lack of wear they experience.
  8. Sam_
    Sam_ Down under
    3,038
    480
    But that's just a support for the the "main" bolt isn't it? Agree though, doubt it does much compared to the other...
  9. Welly
    10,696
    130
    Yes, but it's pretty rigid and means the whole assembly moves pretty much together. The big back bushes on the dogbones are the ones the change, they see the wear.
  10. karl210
    karl210 Member
    324
    So are you saying its not the bush i need and i need the whole dog bone? ive got a morning off work tommorow so could do with making a decision by then so i can pop upto awesome to get one as the engine is rocking quite a lot with just my hand, cheers
  11. Welly
    10,696
    130
    I would suggest starting with the rear bushes. The big ones in the fat end of the dog bone.
  12. karl210
    karl210 Member
    324
    i was under the car yesterday morning tugging on the engine and the rear bushes are fine, i can see its moving where the other bush is and its pretty much disintegrated.
