Dogbone Bush Problems!
[Dave B] Mar 6, 2011
  1. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I've spent today doing some bits on the car, namely rear caliper return springs, some new aesthetic engine parts (covers etc) and the diesel dogbone bush.
    Everything went well apart from the dogbone bush, when trying to undo the 13mm bolts which attach the mount to the subframe, one of the bolt heads sheared clean off :(
    I've now aborted the job until I have new bolts, but I need some info/advice:
    1. Anybody know the part numbers for the 13mm bolts?
    2. Has anyone got any ideas how I can get the rest of the bolt out of the mount?
    At least the caliper springs went in ok (handbrake is great now) and the engine bay looks tidier....
  2. Dani_B19
    9,382
    403
    Drill it out? Cant you buy a removal kit aswel?
  3. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I'm not sure about drilling it out but I like the idea of a removal kit....it's google time.
  4. steve bain
    steve bain Member
    642
    if you mean easi out, don't do it!! they snap off and they are the hardest thing to drill ever! i blunted 6 cobalt drill bits removing one once. did it snap flush? if not, mole grips and heat...
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Have you got the part numbers for the springs, and where to get them .....
    plenty of lube on the snapped bolt then try drilling and put a left hand screw in...or get a nice little chisel and tap away
  6. [Dave B]
    [Dave B] Daddy
    2,027
    145
    It snapped flush to the dogbone mount so if I can get the mount off over what remains of the bolt then I might have something to play with. I'm not going to try until I have the new bolts though.
    The part numbers for the springs are 7M0 615 295 and 7M0 615 296. I got them from Stoke Audi off here, they were about £4 delivered, well worth it IMO. Dead easy to fit too, info here mk4 golf rear caliper - modification to help unstick handbrake - Club GTI
  7. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Ok, I've had a look on vagcat and it looks like the 13mm bolts are part number N10268302...
  8. bogard
    bogard New Member
    just done my clutch this weekend and both my bolts snapped flush,any way a bit of heat and plenty of hammering got the mount off. The bolts were corroded into the aluminium mount and once that was off the remaining bits of bolt were only finger tight in the subframe, hope this helps
  9. Westy
    Westy Well-Known Member
    17,443
    1,105
    A 5 min job never always ends up being a 5 min job does it. That's some rotten luck there fella, hope you get it sorted soon.
  10. wibble111
    wibble111 needs to scratch the itch
    841
  11. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    I have done 3 of these, all snapped, the only way to remove the dog bone is to pry it off the snapped bolt, the thread into the subframe will be fine. Its the bolt to dog bone that seizes up.
    Don't drill it out!!!!
    Just take your take and keep levering away at the dog bone from the subframe, When you replace the bolt make sure to copper slip the new bolts up....
  12. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    Molegrips, or 2 suitable nuts. Wind one nut on a bit, then wind the second one up tight to it. Then use a spanner on the first nut you wound on. It will clamp up to the second nut and becomes a make shift bolt head.
    A fantastic method for removing snapped studs - combined with lots of WD40 and possibly some blowtorch action.
  13. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Thanks for the input people, this is why I frequent this forum :)
    I'm hoping the remainder of the bolt will come out when the dogbone mount is removed but if it doesn't I like the two nuts idea....many thanks Welly!
  14. Welly
    10,696
    130
    No probs dude - works a charm normally. Thats exactly how I wound the two snapped bolts out of my turbo - and they were in there big time!
  15. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    Same thing happened to me this weekend, one bolt sheared off, the second one didnt but the dog bone mount crack and split off around the bolt. I just phoned bedford audi, part no. for bolt I was given is N10268304 62p each. Also part no for dog bone mount is 1J0199851R £46.55 so not as expensive as I was made to believe, although i just got one of ebay for a fiver :sm4:. Mines going into TTS on friday for a service and removal of the bloody bolt.
  16. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Wooohooo it's done!!! :)
    The dogbone eventually came of the subframe by using the following techniques:
    - smacking the mount with a hammer
    - levering the mount away from the subframe with a screwdriver
    - applying WD40
    - applying heat via blow torch (obviously not at the same time as the WD40)
    I managed to get what remained of the bolt out by using Welly's two nut process, so thanks again welly.
    It's all refitted so all that's left to do is drive it....thankfully.....
  17. mk1chopper
    1,092
    12
    Result, had mine sorted today, hasnt made any difference to my gear change, guess the syncros are just worn on 1st and 2nd, but the engine seems smoother, was only charged 1/2 hours labour too which was a result, great service from TTS once again :)
  18. Westy
    17,443
    1,105
    Excellent news. Welcome to the cabin vibration club ;)
  19. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Don't say that you b@stard! ;)
    I'm hoping it's vibration free otherwise its coming off!
  20. Westy
    17,443
    1,105
    haha. I'm hoping mine will settle down but I'm going to check I torqued up the bolts correctly tonight.
  21. mk1chopper
    1,092
    12
    did you fit the red or yellow one?
  22. s3dave
    10,110
    736
    I must remember to take the yellow bush off my car,,,,, will feel as smooth as **** with a red one on
  23. Imteyaz
    Imteyaz 6th Gear
    535
    Have you tried setting the linkages up correctly?
    (Youtoob linky: YouTube - Volkswagen Group Shift Linkage Adjustment for year models 2000-2010). I
    had notchy gears until I tried this and it's nice and slick now.
  24. mk1chopper
    1,092
    12
    Nice one will give that a go later
