Dog bone mount woof woof!
cjsuk Jul 2, 2012
  1. cjsuk
    cjsuk Active Member
    567
    80
    I have a creeking and sometimes a knock inside it sounds like its under the middle of the dash (under the car). The only thing I can see is the dog bone round that area. Is that most likely it? I would get down n dirty to look but its pissin it down. If its that do I go standard, powerflex yellow or powerflex red? Cheers :)
  2. putang
    putang Member
    154
    do not get a power flex unless your tracking it. They are horrible for everyday driving.
    They rattle the car to bits
  3. s33nyboy12
    s33nyboy12 Well-Known Member Team Ibis Team V8 Audi R8 s tronic
    1,488
    203
    I've heard red is ok, and yellow you need idle reset with vcds to compensate for vibration ......... Red is labelled diesel btw.
  4. cjsuk
    cjsuk Active Member
    567
    80
    I have done some research and like you both say yellow = no go...... so I will be getting the red diesel one, apparently it will fit fine and I should have no issues and will last unlike standard.
  5. Squirrelofdoom
    Squirrelofdoom Member
    673
    23
    I fitted the Red Powerflex into my dogbone literally yesterday and it's fine. There is absolutely no extra vibrations and the engine now doesn't sway about like mad lol. Go for the powerflex red, no worries with them
  6. andya3turbo
    andya3turbo Member
    85
    i will be investing in the red one soon and if it makes the car feel like a tank i will be selling on lol
  7. Prawn
    11,609
    3,587
    I disagree with anyone say the yellow powerflex mount is too stiff, you need to give it time to settle in.
    I've run the yellow mounts on many cars, for myself and others, for years. they settle down after 500 miles or so and you don't notice it at all.
  8. G60DAN
    G60DAN Member
    383
    I've got the red one and its fine no vibration at all.
  9. Sam_
    Sam_ Down under
    3,038
    480
    I'd agree with Prawn. The dogbone bushes need time to bed in a little. I just fitted a VF dogbone (much harsher than a yellow I'd expect) and that took some time to settle in, but now it feels much tighter than the red bush, which I like. I did fit VT top engine mounts prior and that was a good combination too (VT top engine mounts, red dogbone bush) if you like being a little less "connected".
    The VF doesn't have much give:
    Worth noting a lot of people don't change the small bush, which I've heard helps too (makes sense).
