Does your S3 oversteer when pushed hard round corners?
Andrew@A.L.D Jul 19, 2009
  1. Andrew@A.L.D
    3,879
    617
    When out today in the S3 today and found some nice twisty's roads, seeing as i've only had the car for 3 weeks and never pushed it hard in the corners i thought i would give it a go.
    Well i found out it oversteered witch is very fun but is this normal for a S3?
  2. j4jon
    j4jon Member
    704
    No completely the opposite! Standard S3's will understeer when pushed hence why people spend a large chunk of cash changing all the suspension, ARBs and having the geometry done.
    Is you car standard or has it been modified in any way?
  3. Andrew@A.L.D
    3,879
    617
    I think its been lowered a little, its running RSTT 18's and thats about it?
    No understeer at all in mine but when pushed hard it will go into oversteer
  4. S3 HODGE
    S3 HODGE Brown passenger seat.
    1,200
    Mines standard in the way of handleing and depending on what the corner/road surface is like i sometimes feel the back wanting to come out but mainly understeer :ermm:.
  5. Keeno
    Keeno Spooly Spooly Boosty Boosty!
    701
    Some sort of crazy-ass Haldex phenom causing lots of power to the rear? :unsure:
  6. au_sjo
    au_sjo Member
    102
    My old standard S3 used to understeer badly on the edge.
  7. god_thats_quick
    2,507
    Having had an S3 with worn suspension, new Audi suspension and Bilstein B8s / H&R springs (and uprated ARBs) here's my current thoughts.
    On all suspension, carry too much speed into corner and you will understeer (pretty obvious)
    With stock suspension when not totally knackered on big roundabouts it was possible to get power oversteer however it needed serious abuse of second gear, slowish in and then hard on the power.
    With the current suspension and decent geo it does the above but is if anything harder to get to slide as it has more grip overall however when it does slide it's if anything more progressive and controlable on and past the limit, I also had my car remapped at the same time so it's better even with more power.
    The thing that surprises me now is that the car appears to be more prone to a full on 4 wheel drift rather than just the back coming round as it would have done before on the stock suspension but like I said I think that's because it's got more grip and it's actually better balanced.
    I also found tyre pressure and geo made a massive difference when really on the limit, especially on a smooth track.
    Just my 2p after doing something like 120,000miles in one...
  8. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    Lift off oversteer? Thats the only time I can get it to oversteer with standard suspension.
  9. Lacey123
    Lacey123 Audi S3
    33
    Mine oversteers if chucked in hard at a corner its on coilvers and thats it.
  10. ChriS3
    ChriS3 hud at ye bam
    2,239
    27
    Lift off oversteer is about all you'll get unless your rear tyres are knackered. I've had power understeer/drifting and mid-corner skipping, but never, even with an uprated Haldex and a big turbo, had proper oversteer.
  11. bantam1
    bantam1 Member
    529
    If I postion my hands at twenty past six on the steering wheel i can get understeer!
    Very bored at work today.
  12. Gareth_RS3
    Gareth_RS3 Member
    125
    Never had proper oversteer, lift off maybe but that was it,
    Maybe more likely with uprated arbs and anti roll bars coilovers uprated haldex etc but still think its unlikely not saying it didnt happen just my 2p
  13. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    possibly due to the fact your lowered but with no geo setup so the wheels are cambering more so the gain less grip in the corners, also do you have rubbish or worn tyres on the back as when i had rubbish tyres in the wet it used to oversteer loads and was great fun,
    mine power oversteers still due to my setup, great fun
  14. ianysm
    ianysm Active Member
    1,002
    Mine 4-wheel-drifts out of roundabouts (remapped), but never had oversteer (unless lifting off or left foot braking too hard!)
  15. Dennis Moeller
    Dennis Moeller Member
    444
    Excactly my experience too...Mine's now very balanced on the edge and I can get in to some "serious" 4 wheels drifting...Otherwise very good grip and a very neutral behaviour. I have worn tires tho and have only gotten into a drift on a track...Did this track a while ago with a nice second-fourth gear pace...drifted from side to side but the car was very controllable and it really all came down to the tires and the lack of grip...On the road I haven't been able to get the wheels to slip yet...only if the tarmac is wet...But that is some what scary due to traffic and all...
    Upgrading the suspension and setting the geometry right totally changes the car...well worth the $$$
  16. mephisto
    mephisto Member
    256
    17
    Interesting thread, whilst shadowing an eratic rookie M3 driver the other week into a roundabout i actually found the rear of my S3 going, but that was combination of lift/braking heavy into roundabout, the entry to the roundabout curved left as i was still braking hard.
    So swinging one way to the other whilst applying heavy braking/lift off should/may invoke oversteer.
    However... My S3 happily oversteers in wet, but that's because im currently running some shoddy Avons on the rear and new GoodYear F1's on the front, which i do enjoy :)
    I gather you've checked the obvious like rear tyre pressures, stock suspension or adjustables etc.
