Does this quote seem OK?
trogen Jul 10, 2007
  1. trogen
    trogen Member
    47
    Please let me know if im getting raped on any of this guys :)
    1x front break pads = 52.50
    break disk (vent) 312x25mm 5/100 = 105.00
    Oil filter = 5
    air cleaner element = 11.59
    Filter elemient with odor and harmful substance filteration = 13.13
    Spark Plaugs... (longlife?) = 37.20 (for 4)
    oil filter 21.64
    high performance oil for hadlex 275ml = 9,61
    Oil = 30.00
    Labour = £120
    TOTAL= £405 approx
    Its done 80k and has just had the cam done about 5k ago.
    Thanks,
    Jamie.
  2. madvw
    madvw Active Member
    2,489
    sounds OK to me. Pads and discs maybe a bit expensive. They're only charging you £60 an hour for labour by the looks of it.
  3. steebo888
    steebo888 Member
    218
    i would probably do the brakes myself
    http://www.vwspares.co.uk/a3brakes.php
    pads and discs total from above = £94 inc vat £10 del £15 caliper piston rewind tool (halfords) - Grand total = £119
    your quote £155 + £60 labour (1hr) Grand total £215
    nearly £100 saving
  4. trogen
    trogen Member
    47
    Yeah labour is cheap because i know the guy, but i still wanted to check because you neva know with mechanics ;)
    So you would say the pads and disks are a little expensive. whats that website with all the audi parts on it?
    Thanks again lads.
  5. Dave_Bayern
    Dave_Bayern Slipping at 3.5Krpm
    1,913
    They'll be Zimmerman vented fronts, and thus should only be £50. For £105 you can get Black Diamonds, so thats too much.
    Pads are an OK price as long as they are genuine or Mintex.
    Oil Filter £21??? Should be £7 at most.
    Check on the type of the spark plugs, standard genuine Bosch ones are £3 each from GSF
  6. madvw
    madvw Active Member
    2,489
    depends.
    OEM NGK's for s3 are £10-14 each.
  7. Dave_Bayern
    1,913
    Vented discs arent OEM, so I assumed they wouldnt be entirely OEM parts, hence overpriced unless thats for some Denso Iridiums (about 4 billion times better than NGK's)
    EDIT- I am now assuming Vented as in standard vented discs, solid, but vented in the middle, as per OEM.
    Available from GSF for £41+VAT in 312mm for S3.
  8. trogen
    trogen Member
    47
    No i have all the part numbers too and checked the prices of the parts on VAGparts and they all seem to be ok... except the breaks (pads and disks)
    That quote is from Audi in reading except my friend is doing the labour for a little cheaper.
    The vented disks are part number: 8N0 615 301 A
    Pads part number are: 1J0 698 151 M
    The oil filter you said was expensive is 15.90 on VAGparts so about a fiver cheaper, but im not gona cry about a few quid here and there.
    How long would it take an Audi engineer to do pads and disks on a car... front only? An hour? half maybe?
    J.
  9. Dave_Bayern
    1,913
    The oil filter is still overpriced, you can buy a Purolator filter for £6.99 (Better than OEM).
    However, total time for the brakes and the rest of it would be about 2 hours, and £60 an hour is fine compared to the £99+VAT an hour that Ridgeway Audi charge.
  10. bouncer--daz
    bouncer--daz A dog is for life....not just for friday nights!
    537
    Buy the parts your self and get the mate too fit them... just tell him you know someone with a trade discount card... his feelings wont be hurt then. The brakes are an easy job to do yourself aswell!
  11. steebo888
    steebo888 Member
    218
    yep i agree especially with the brakes. mine are due so i will be buying all oem parts cheap and doing it myself.
    even halfords AA quoted £480 for front and rear pads and discs supplied and fitted.
    i can get the oem parts for approx £160 and the caliper piston rewind tool for £15
