does this camshaft look ok
nokia_aid Dec 14, 2011
  1. nokia_aid
    nokia_aid Member
    47
    does that cam look ok,still not found the problem with the car so wondering if it could be the cams
  2. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    cams need to be removed to check
  3. SWILKO
    SWILKO Member
    105
    What's the problem?
  4. nokia_aid
    nokia_aid Member
    47
    Car is a 140bhp tdi audi a3 with a BKD engine
    The problem is bad smoke on startup (its definatly diesel smoke)
    will smoke badly on cold startup and doesnt start very well
    the bad smoke on cold startup will stay for a good few minutes if i leave the car on tickover but if i drive the car right away the smoke is gone in a few seconds and it doesnt smoke then unless i turn it off and start it from cold again.
    when its warm it starts fine and does not smoke.
    when im driving it does feel like i get the odd misfire sometimes
    Vagcom says misfire on cylinder 1
    I checked my injector readings and i get
    cyl1 cyl2 cyl3 cyl4 measured in mg/str when cold
    2.99 -3.01 2.79 -2.78
    when the car is upto temp it goes to
    2.82 -1.6 -0.73 0.45
    from what i can gather reading online injector 1 is injecting out of spec and injector 2 is trying to compensate for it same with injector 2 and 3 when cold but when warm injector 2 and 3 are within tollerance but injector 1 and 2 are still struggeling
    things iv tried
    checked coolant and its not loosing any
    fuel pressure is fine
    changed glow plugs
    changed injector loom
    changed injector 1 and when the old one came out had an x on it so from that someone has already swapped them at some point cos iv been told that means they are exchange units
    changed tandem pump
    changed starter motor
    changed the MAF
    compression tested cylinders and they were fine
    the car has had a full service
    Does anyone have any idea what I can try next
    i do have a ross tech vag com cable so can check more reading if needed
  5. SWILKO
    SWILKO Member
    105
    Got to be honest, you've done tons of research. The only reason I asked was because my cam in my old PD 150 Golf went down as one of the lobes was worn down. Up until that point there were none of the issues you mentioned. Only way to check the cam is, as mentioned, to remove from the engine.
  6. nokia_aid
    nokia_aid Member
    47
    so what issues did your car have when the cam went,
  7. Virdee
    Virdee Active Member
    172
    25
    There are sealing rings on the injector. There is a repair kit from Audi. Around £18 or so per injector.
    We've seen this issue on several 1.9 and 2.0 TDIs.
  8. nokia_aid
    nokia_aid Member
    47
    is there anything else you think it might be,i did already have injector 1 changed with new seals
  9. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,380
    214
    well its not cams i can assure you. My guess would be a valve stem oil seal leaking down when its left over night. Poss a dribbling injector ?
  10. nokia_aid
    nokia_aid Member
    47
    that was my first thought a leaky valve seal or injector but its not an overnight issue,if i start the car leave it running till it clears then turn the car off for 5 mins and start it again it smokes again, but when the car is warm i can leave it for 5 hours and it wont smoke,also its definatly diesel burning theres no oil burning.its a really ****** of a problem to solve,
  11. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,553
    896
    My previous 2.0 TDI had a very similar problem......sluggish to start and very smokey. Turns out there was an internal leak across the tandem fuel pump and the oil was getting sucked into the fuel system clogging the injectors and filter. As it was under warranty Audi replaced the pump, filter and injectors. It took them 2 attempts to get a serviceable tandem fuel pump as the 1st one they fitted had the same problem and that was new.
  12. NHN
    29,576
    1,779
    I'll be very interested to know what the problem is, fair bit changed already.
    Curiously, have you had the ecu reflashed by audi, has it had a remap at all?
  13. nokia_aid
    nokia_aid Member
    47
    iv checked the fuel system for any oil residue and there is none in there.
    the car has never been remapped that i know of,on the pistonheads forum a guy on there that seems to know his stuff has recommend i change all injectors and seals,i got a spare engine off ebay the other day with injectors in it so il buy some new seals and fit those in and see if that helps,he also told me to check where the injectors sit in the head as that could have worn giving me issues,im hoping to god that changing all the injectors and seals fixes it as after this im running out of ideas,lol
