Does the b7 upper dashboard fit the b6??
Dan TheMan Welburn Jul 2, 2012
  1. as above! ive been wanting to change my dull grey upper dash to black and dont fancy vinyl painting it due heat from the vents etc, so ive been trying to find a b6 dash in black but theyre askin stupid money for them, ive found a b7 one for £100 and was wondering if its the same?
  2. vr6gordy
    vr6gordy Well-Known Member
    2,826
    191
    yes there the same
  3. PhilW
    PhilW Member
    182
    Are they easy to change out?
  4. vr6gordy
    2,826
    191
    it will be a mare to do i bet everything will have to come out i guess
  5. swarcup
    swarcup Well-Known Member
    1,326
    40
  6. benjie
    benjie Well-Known Member
    1,223
    305
    I've done it, took about 2 hours to get everything out, done at a sensible rate... Get a Haynes manual, it was very helpful and spot on with the instructions and pictures.
  7. hades-
    9,482
    646
    quite easy to do just got to look for hidden bolts etc
  8. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    132
    Whats the difference the one in the link above looks the same
  9. Dont rush into it!!! i have and now i have a dash out of a b7 to go into my b6 and the passenger airbag frame is different so unless you get the airbag with it i wouldnt bother, the brackets that bolt to either side of airbag are different also unless this dash ive been sold isnt from saloon :S im trying to make a gd dash from my old one and the new one, its not easy, im going to have to swap the brackets somehow,
    Anyone got any suggestions???
  10. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,811
    54
    they are easy to do, take your time and get your nose under the dash to see the bolts
  11. well the b7 one isnt unless you get the passenger airbag with it, and even then there is one bracket that is different, i damaged the b7 one i bought but managed to source a b6 avant breaking locally so got a straightforward one for 50 notes
