does facelift climate control have same wiring as the preface lift climate control
Discussion in 'A3/S3 Forum (8L Chassis)' started by claudefrog, Jul 13, 2007.
  1. claudefrog
    claudefrog Member
    Dec 13, 2006
    372
    Just wondering if it is possible to update the pre-facelift centre dash to the facelift centre dash in the S3
    I have a preface lift car, and thinking of upgrading to facelift dash, wondering how viable this job is to do?
  2. Advert Guest Advertisement
  3. hooley
    hooley Member
    Jan 26, 2007
    199
    In a word.
    No.
    There is someone on here who has tried, if you do s search you will find their pleas for help with regards this. Mostly unanswered.
    Thought about the same thing myself, and ruled it out as a lot of money and effort to get stuck with incompatible wiring.
  4. claudefrog
    claudefrog Member
    Dec 13, 2006
    372
    thanks, as I said just a thought at this stage, no point in getting a load of butchered wiring just to make it work :)
  5. mwstewart
    mwstewart Member
    Sep 6, 2005
    199
    In the most part, yes, however; you need to ensure the unit is from a car without CAN, as these units use CAN to let the ECU know the A/C compressor is active. CAN units will plug in and work, but the ECU will be unable to compensate for the cycling A/C pump and engine revs will fall as the pump is cycled.
    I had a 1995 A4 with no air con and manual heater controls, to which I retrofitted air conditioning and climate control. I used a 1998 loom (same as the pre-facelift S3) so it was compatible with my non-CAN setup, but used 1999 climate controls as I was upgrading the dashboard to a facelift look with symphony 1 double DIN.
    To get a facelift HVAC unit working with an old loom you will need to swap over a few of the pins. This was a few years ago now, to my memory the illumination pins needed adjustment, there was something else too but I just cant remember without checking the wiring diagrams.
