Does anyone know????
richiexx Oct 18, 2012
  1. richiexx
    richiexx New Member
    9
    Hi all, yeah am new on here guys, just recently aquired my first audi, its a 3 door 3.2 with dsg on a 54 plate, 2 owners with full audi history and 49k on the clock. So far am really happy with the car, its very clean and straight and drives nice and tight, however the the EML light came on today so i have had it plugged in and its showing codes p2415 02 sensor exhaust sample error bank 2 sensor 1 and code p2197 02 sensor signal biased/stuck lean bank 2 sensor 1. Can anyone tell me which is sensor 1 please as you are stood over the engine bay, sorry if this question has been asked a thousand times guys but i just want to get to the bottom of it as i really enjoy the car. Would like to get it sorted asap as it is going into wakefield audi soon for coil pack recall check and dsg service plus haldex service. Many thanks . Rich
  2. murran
    murran Well-Known Member
    1,545
    39
    well bank 2 is whichever cyl 2,4 and 6 are. sensor 1 is up stream of the cat.
    to pin it down 100%, clear the codes you have so you are fault free. unplug the suspected lambda, switch the ignition back on and re-read the fault memory. if you now have "lambda sensor bank 2 sensor 1 - open circuit" then youve found it!
  3. richiexx
    richiexx New Member
    9
    Thanks alot for your reply murran, i,ve cleared it twice now and it comes back after a few miles, it never says 'open circuit' it always comes up as '02 sensor exhaust sample error' or sometimes '02 sensor signal biased/stuck lean' Am i right in saying the 3.2 has 3 lambda sensors? 2 upstream and 1 downstream? Thanks .Rich.
  4. murran
    1,545
    39
    no, i mean you know it says two faults relating to b2s1 sensor.
    you asked which sensor it was? a way to tell is to unplug a sensor. the sensor will be open circuit with it unplugged. on reading the fault memory again it'll say "b2s1 sensor open circuit"! then you know thats the correct sensor. if it says b1s1 you know its the other one.
    im not sure if it has 2 pre and 2 post cat lambdas. does it have 2 separate cats? if theres two cats it should have 4 lambdas.
  5. richiexx
    richiexx New Member
    9
    Thanks again murran, i have a new sensor so i will try what you have said and let you know soon, hope it workscos i love the car
