Does anybody know how to get this off my front window screen ?
J.R. May 29, 2013
  1. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    I'm changing my rear view mirror to an Audi TTS version.
    I've just realized the front window screen mounts are different and I need to change it in order to fit this rear mirror
    ..but I'm having trouble getting the old one out ...it's probably been there since factory ...
    Can anybody advise on how I would get this mount off my front window screen ?
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    White spirit /solvent to dissolve the adhesive.
  3. ron burgandy
    ron burgandy Active Member
    281
    My guess is it can't be taken and if you use force you'll crack the windscreen
  4. Jord
    Jord Member
    280
    dont force it, i smashed my windscreen when i did it on my polo
  5. Ads
    Ads License to drive
    8,230
    608
    Forget the mount mate, I'd be more worried about that UFO hovering outside your yard.
    Sevv, J.R. and MacrosTheBlack like this.
  6. mjr901
    mjr901 Guest Gold Supporter Audi S3
    3,595
    1,063
    cheese wire
  7. max69vk
    max69vk Active Member
    862
    57
    When I worked for Autoglass we used to heat the disc up with a mini blowtorch then twist it off with a pair of grips. You'll also need to have the correct glass adhesive to re-attach it to the new glass which is a headache with a fitted windscreen as you have hold the disc in the correct position till it sets enough to hold it.... Which is about 4-5 minutes!
    Whatever you do, don't use superglue. The heat generated from the chemical reaction will crack your windscreen.
    J.R. likes this.
  8. J.R.
    1,405
    68
    Do you know if Auto-glass do this when installing a new front window ?
    I might just get a new front window and let them deal with it.
  9. Sevv
    Sevv Pushing the limits..
    1,321
    118
    just for a rear mirror ? you are that keen on fitting it you'd change the whole windscreeen
  10. J.R.
    1,405
    68
    lol ..I was planning on changing it as I wanted the auto wipers ....which I don't have on my car.
  11. max69vk
    862
    57
    Go down there and ask them to swap them over, one of the fitters will probably do it for a couple of beer tokens ;)
  12. AndyMac
    9,832
    45
    Heat it up with a heat gun the use dental floss to saw it off
    J.R. and s3reptdi like this.
  13. honeybear
    honeybear New Member
    27
    ADS>>>>nice one Mate LMHO
