Dodgy xenon bulbs??
DJ_Troopa Dec 19, 2009
  1. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Evening everyone
    Purchased new 6k D2S xenon bulbs recently. When i turned them on the driver side bulb flickered and went off. After flicking the headlight switch on and off about 20 times the bulb looked like it was staying on for longer (as if it was warming up or something) and then finally stayed on! Just to note, i turned the lights off again, put them on, and came on straight away.
    So i returned them thinking the bulb was dodgy and went to another Ebayer and got bulbs from there instead. Now i have the same problem again but with both bulbs!!
    I put my standard original ones back in and they turned on straight away no hassle!
    So i'm thinking... could they be dodgy bulbs? I got them from Ebay for £20 a pair. Yes i know it's Ebay after all, but is my luck just really **** with these at the moment!?
    Thanks people, hope you're well.
    Jay
  2. golf
    golf ***** rent boy VCDS Map User
    1,556
    I find that in the cold weather I sometimes only get one xenon powering up, while the other takes a few tries. I always assumed it was a glitch with the ballast, but maybe I'm wrong.
  3. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Yeah i get what you're saying as i thought the same thing too. But the fact my original bulbs work straight away has just puzzled me!
  4. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    Same here exactly same happened with me... Dodgy bulb, had to send it back for another one!
  5. Prawn
    11,354
    3,190
    I recently fitted some aftermarket HID's to mine, and I get this exact same issue in the extreme cold.
    the drivers side always fires first time, but the passnegers side sometimes needs the lights switching off then on again for it to fire.
  6. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Fran-S3: What happened when you got the new bulb? Did it work fine then?
    I have found a temporary fix for this problem and working fine with me since yesterday. Turn the lights on and leave them on. The 'no bulb' picture will appear on your dash with a loud beep but ignore this and just leave them on for around 20 seconds. Turn the switch off and turn them on again and they work! Try it out, works for me fine!
    I'm gonna get new bulbs anyway but at least my lights come on quicker this way and i won't end up breaking my switch with all that turning!
    Jay
