Dodgy boot lock
bradh Sep 16, 2013
  1. bradh
    bradh Active Member VCDS Map User
    557
    58
    Hi chaps some times it take one push others several push's to get my boot to latch its as if its bouncing out the lock
    Any idea on what I need to replace / change to fix this issues please as it's quite annoying when tipping it down and I'm getting wet lol
    A4 estate ;)
  2. bradh
    557
    58
    also some times when the boot is actually shut the dash lights up with the boot open section flashing at me could this be connected?
  3. Ollie-B
    Ollie-B Rockin' Shnit
    328
    Try some wd40 on the latch
  4. colinurquhart
    colinurquhart Member
    203
    34
    I had the same bother there's a small switch inside the lock which goes. I've just replaced mine with a new latch mechanism for under £30 from Audi. Well worth it as gets stressful when it doesn't shut and just bounces.
  5. Silky
    Silky Member
    51
    Do you have the part number for that?
    Mine does the same, if I shut it and it makes the non-shutting clunk sound, I wait for the electric noise to finish, it then shuts fine. But would prefer a solution to it
  6. rbailey88
    rbailey88 Active Member
    132
    29
    I had same problem during winter, wd40 on the latch and trigger solved it for me mate, might be worth a try before replacing parts.
  7. colinurquhart
    203
    34
    When you ring your dealer for the part give them you reg number and they'll get a part number from there. I never even looked elsewhere as dealer wasn't expensive.
  8. bradh
    557
    58
    thanks guys ill try wd40 but think ill be ringing the dealers too if its only £30 notes :)
  9. Mothy69
    Mothy69 in gear but clutch slipping
    167
    9
    Mine does this too. Thanks +1
