Do you have a bkd engine?
Ade6 May 13, 2013
  1. Ade6
    Ade6 Member
    101
    Does your car make a subtle cricket sound with the windows down and the radio off when driving down the road? Sounds like its coming from the turbo aria?
  2. Double J
    Double J Member
    93
    15
    Cricket? As in the insect? Like a clicking?
  3. Ade6
    Ade6 Member
    101
    Yes it sounds like a verry faint cricket noise when driving with the window open and the radio off you can just hear it! More so when passing cars or buildings. Of if you rev the engine a little and let the throttle off you can here like a kinda rattley noise! Abit like a pully bearing noise!
  4. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    Nope. But I hear a hissing noise which turned to be a split hose between the turbo and intercooler.
  5. sliced
    sliced Drive safe, stay alive.
    1,562
    334
    might just be along the lines of that, probably an alternator belt or something?!
  6. Ade6
    Ade6 Member
    101
    Sounds like that but its the same when the aux belt is off! So that eliminates any chance of those. It could be the sound of air escaping somewere maybe? It goes away when i pull the pipe off the actuator and rev it.
  7. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    I get your rattle noise on release of throttle as it comes back down to around 1k-1.2k rpm I suspect it's my DMF
  8. Ironborn
    Ironborn English...not so good
    1,179
    227
    Yes I used to get this as well, I had it for quite a while but ignored it. After a waterpump and cambelt change, it just went away. Don't know what they messed around with in there, but free fix :happy:
  9. Ade6
    Ade6 Member
    101
    It sounds like its coming from the rear by the turbo and goes when the actuator pipe is pulled off. Its had a waterpump and cambelt too! But still the same noise.
