do these wheels fit my b5 avant
gruf Feb 23, 2009
  1. gruf
    gruf Member
    288
    14
    they come off 8K A4
    Type - Audi Genuine 7 spoke 17"
    Part number - 8K0601025B
    Size - 7.5JX17 H2
    Offset– ET45
    Stud pattern – 5/112
    Tyre Size - 225/50/17 94Y
  2. aragorn
    18,608
    871
    those dimensions are exactly the same as B5 S4 wheels, so yes they should fit just fine.
    One thing to note, is that they changed the centre bore size on B8 A4's from 57.1 to 66.6mm, that means the wheels will fit your car, but wont locate correctly on the hub, which can make them a bit tricky to fit.
    You can always get some spigot rings turned at a machine shop to centralise things, and it shouldnt affect anything once the wheel is bolted up.
