Do the Adaptive Lights do this??
N8 Dec 6, 2007
  1. N8
    17,163
    718
  2. Issac Hunt
    1,162
    They will go up and down if you have Xenons.
  3. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
  4. N8
    17,163
    718
    No Staz, thats just what happens when they are turned on!! But normal xenons shouldn't go up and down though issac. Its only Bi-Xenons (i.e. xenons + adaptive lights) because the light unit is able to move. All the cars I've owned, and friends owned with xenons don't go up and down! (i.e. clio 172, tt etc)
  5. emzino
    emzino Active Member
    1,231
    Well i'm on a 53 plate A3 with Xenons and they go up & down I can assure but not left & right...
  6. N8
    17,163
    718
    Yeh I know. I said that, its AFS - Adaptive Front Lighting System, they are on the passat are they on any of the Audi range, does anyone know?
    Thanks. I saw this video and even the leon has afs
    http://www.youtube.com/watch?v=8wGeSNYxJLQ
  7. Staz
    6,206
    64
    Yes exactly. Most systems do a self test when you turn them on. That way there's less chance of turning on the lights and going round a bend and then the lights getting stuck facing to one side, leaving you blind!
  8. N8
    17,163
    718
    Oh yeah, I got you. :icon_thumright:
  9. s3mike
    s3mike Member
    240
    My adaptvie xenons, go down, up and then do a little left right movement when turned on.
    Looks quite cool reflected back of the garage door!
  10. N8
    17,163
    718
    Get the vid up!!! Thanks
  11. Amchlolor
    Amchlolor Active Member
    5,604
    My wife's Clio has 'extra' front lights, built into the side of the headlight, that illuminate when you turn the wheel.
    They seem like a gimmick, they actually work very,very well.
    Merely being additional lights, no chance of them seizing and no added weight of motors.
    http://www.renault.co.uk/Safety_Video_CorneringLights.aspx
  12. Staz
    6,206
    64
    Is that all they did though?? My mate had a vectra vxr and the lights moved left and right but when turning at slow speeds an extra light came on too.
  13. N8
    17,163
    718
    Bi-Xenons its built into the main light. You're chattin about an extra light. the mercs and cayennes have that as well as does my cousin clio 197!
  14. Issac Hunt
    1,162
    I can assure you my Xenon lights go up and down EVERY time the lights are switched on, its part of the auto-levelling initialisation procedure.
    Bi-Xenons ARE NOT Xenons + adaptive lights. My B7 A4 (07) has Bi-Xenons, this means the the dipped beam and main beam are both Xenon. As oppose to some earlier A3's for example that only came with a Xenon dipped beam and a normal halogen bulb for main beam.
    Adaptive lights mean they will turn to the left and right when your cornering. This is an additional option on top of Bi-Xenon headlights, which my current A4 does not have.
  15. N8
    17,163
    718
    Thankyou Issac, I think you've just cleared that up for me! Excellent!
  16. JohnS3
    JohnS3 Active Member
    3,028
    Does anyone kow if you can retro fit the AFS motors (and controller) to the existing bi-xenon units?
  17. N8
    17,163
    718
    That is a very good question, Audi don't do it - I check the uk site, but in the vid I posted its on a Passat and also on a Leon as well? I dont understand why they would install it onto those cars and not the Audi range?
  18. José
    José Member
    35
    Since we're talking about the xenon lights, I have had a lot of complaints from the other drivers, because the lights are too high. It's strange because the calibration is automatic and it should be allright. Can't we manually lower the lights a bit? I only notice the lights adjusting in the garage and when I move from a standing position.
  19. N8
    17,163
    718
    That is weird hose.
  20. si_reading
    si_reading Member
    168
    I've seen this on Clios at work too - quite a good feature that does work. Didn't know what it was at first when I drove it in the dark lol.
  21. Nitronic
    Nitronic New Member
    27
    :icon_thumright:
  22. drnutta
    drnutta Member
    371
    Hiya,
    I can confirm that the adaptive lights do this!
    All working now :laugh:
  23. Marcyboy
    Marcyboy Member
    119
    My Previous Focus ST 225 had Xenons (Factory) .. and these were Not Bi Xenons.... and they went up and d own self testing like my std Audi ones... Also the other Half's Clio 182 also does this....
