Do K&N Panel Filters Make a difference??
leecs3 Jun 22, 2006
  1. leecs3
    leecs3 thinking about stuff
    604
    Thinking about buying one, but can you feel the difference? Going on a bit of a thrash with my friend (3.2 8P Quattro A3), want to make sure my revo'd S3 has the bigger muscles. What do you think??
  2. madvw
    madvw Active Member
    2,489
    no point, been tested and proven on here to provide no BHP, but give seom induction noise.
  3. DPM
    DPM Site Sponsor Site Sponsor
    4,942
    185
    The kone made my S3 over heat when in traffic and helped with the break down of my MAF! Don't know what the filter will be like!
  4. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    It definetely makes more of a sound when the turbo kicks in, which is all good, but I don't think you'll see any power gains.
  5. dummi
    dummi smoking a6
    1,210
    i found maximum flow is same as stock filter, but its response to airflow is much faster particularly in turbo cars turbo got boost faster and worth it for that
    in NA cars its almost not worth, car pulls a little better, but on the commute used more fuel, on NA i'd mostly stay with stock filter
  6. Dan Gliballs
    Dan Gliballs Active Member
    1,568
    So a K&N panel filter will give a little more noise? :)
  7. mattyboy199
    mattyboy199 Well-Known Member
    1,885
    why not a foam pipercross filter (panel) instead ?
    Their cheaper & i would of thought foam would provide better air flow
  8. millsyd
    millsyd Member
    114
    foam isnot good as it breaks up and if it gets sucked into the turbo it acts like grit which will damage ant turbo, go green cotton or k and n but it wont give any xtr bhp, just noise and pick up a bit better. i have the k and n pannel filter on mine.
  9. Stringster
    Stringster Missed gear
    390
    K&N in mine - more noise and maybe a quicker response.
    Had foam filters before on a Mk2 Golf 16v. Found they got very dirty and broke up quickly. Not impressed.
  10. JGrant1285
    JGrant1285 Sir Scouser Benitez
    225
    i'm looking as getting a K&N panel filter on my 52 1.9TDi, will this make it gulp more fuel? also i'm looking at getting a louder dump valve for it, maybe an adjustable one, has anybody got any ideas where the best place to go to get either of these???
  11. DIPS_A4
    DIPS_A4 SEAT LEON CUPRA R (225)
    570
    im interested in a dump valve for my tdi will it fit onto my model. i had a bmc filter took it out just put my piper cross panel filter back in again.
  12. dummi
    dummi smoking a6
    1,210
    do you seriously want a dump valve on a tdi think about all the boost you will lose you will be down to the original 30bhp or whatever the 1.9 puts out without a turbo pretty much.
  13. DIPS_A4
    570
    True say i totally forgot about never thought about it was thinking about the noise more. good point man.:thumbsup:
  14. JGrant1285
    225
    ^^ is that DV adjustable to not???? i ideally wanted an adjustable one, so that i can see what the best noise/power balance is. Cheers
  15. The Slug
    The Slug Active Member
    1,869
    It does, i notice a difference straight away, like many say on here probably no extra power but defo does something to the throttle respone, worth every penny for the Pipercross!
  16. nick7602
    nick7602 New Member
    15
    I put the free flowing panel filter in my, daily commuter bus namely my 2.8 Quattro and I did see a good power gain.
    I used to have a Golf MK 3 GTi years ago and I bought a Air scoop and hose kit from Bonrath of Germany , which was connected to my lower bumper, fed directly to the air box this gave good power, the route for the air currently in our Audis is very restrictive in one way.
    so I used the same principle as the Bonrath kit, with my Audis air box and hey presto more power...........ok not mental power..........but def more power ide say about 6 BHP and yes better throttle response this project of mine is ongoing, and I shall keep you all informed if I can reach a better power gain, think its cost me £15 so far for 6BHP not bad really.
    A big problem for most if not all Audis is the dual mass fly wheel, we would all see better throttle response etc with say a chromoloy fly wheel the engine would spin up faster.
    Hope you guys enjoyed reading this Im sorry I dont know how to up load digi pics etc, unless somebody can put then on this forum for me.:blackrs4:
    Nick
  17. Ess_Three
    Ess_Three Active Member
    5,383
    12
    Well that's interesting...as I've never seem a repeatable 'good' gain..
    I too had (and still have a Mk3 GTI and I too have tried the Bonrath air scoop, K&N panel filter, K&N induction kit, modified airbox, home made CAI...and never gained anything when dynod back to back on an independant dyno...
    Some sound better...some seem to pull better...but no power (8v and 16v) despite the manufacturers claims...
    Have you dyno's it?
    I ask because I did similar on my tuned S3 (275+ BHP/330+ lb-ft) and ran a 4" duct into the airbox from the high pressure area where the passenger side IC used to be, ported the airbox and fitted a K&N panel filter...and got nowt. Nothing...
    That's a good point..
    I have a light flywheel on my GTI and it does make a huge difference, as you say.
  18. nick7602
    nick7602 New Member
    15
    well to be honest mine wasnt a standard GTi, it was ported and polished valves changed along with the valve seats, inlet manifold ported and polished, exhaust system etc etc. and I did gain a power lift, i was only handicapped by the awful air flow meter as you know is ****, I could have gone on and on deicided to stop chasing that elusive power hike,and just bought and M3 Evo then followed 8 M3 Evos one after another............tuned them with the help of a mechanic from BMWs touring car days. in the BTCC
    Its like a drug really I just have to do something with the car to improve it in some way really, we went onto mitsi evos and subarus, hence me getting pissed off with the likes of UK tuners ripping the un- knowledgeable among us off, you want to see fantastic tuning parts look at the japanese parts, quality!..........I will say however that the aussies are making some great stuff at the mo, like white line suspension and turbo smart for beautiful blow off valves
  19. Ess_Three
    5,383
    12
    Neither is mine..big valve head 16v, Ti retainers, Schrick cams, matched and flower manifolds, big TB etc...and I still get no gain.
    Oh yes..I'm with you on this one..
    There is some awful Jap stuff out there too...even the 'good' makes.
    Like the Spoon Sports air filter I bought for my Integra Type-R...adds 10-15 BHP they said.
    Lost 10BHP. Dyno proven.
    Utter *****.
    Like much of the Japanese stuff...
  20. nick7602
    nick7602 New Member
    15
