do I need a special tool to wind in the rear brake pistons?
Tom_B Feb 24, 2013
  1. Tom_B
    Tom_B Member
    296
    20
    I need to change the rear discs and pads - one post I read said that a special tool is needed to retract the pistons - is this so?
  2. Bradderz_1988
    3,982
    261
    Yes you need a special tool it can be done without it but is a pain to do !!
  3. Stonefish
    Stonefish Active Member
    188
    54
    It's so much easier with a brake caliper piston rewind tool. You can get them on eBay for £18+postage. Halfords will charge you a lot more.
  4. AlexA4Avant
    AlexA4Avant Active Member
    651
    110
    43
    Yer draper make one tool number 179 works brilliant tool
  5. Mike_B
    Mike_B Active Member
    533
    47
  6. AlexA4Avant
    651
    110
    43
    That's the one brilliant tool borrowed off a mate worked really well
  7. AlexA4Avant
    651
    110
    43
    Do you have to unbolt the central bearing to to remove the disc
  8. jbh
    jbh TDi lover
    1,412
    168
    on the 2wd yes. are you fitting new discs? if so have you bought new bearings?
  9. Chriscooke
    Chriscooke Clueless!
    512
    25
    The key for an angle grinder works on some cars.
  10. mojocvh
    mojocvh Member
    167
  11. aragorn
    18,579
    868
    If its a 2wd you'll need to look for ABS rings too. Most disks dont have them, and you have to either remove the old one and swap it across or buy and fit new ones.
  12. CAR-BOCK: Ersatzteile Audi Seat Skoda VW do excellent prices, discs can be ordered with bearing shells pressed in and abs rings fitted. I bought a full set for mine, FWD, £176 (207 Euro including shipping from Germany)
  13. mojocvh
    mojocvh Member
    167
    I remember you saying they were a good firm to deal with, how are the disks now that you have had them on for a while?
  14. fullpower
    fullpower Member
    159
    pair of circlip pliers does me once u get the nack of it.
