do i need a remap after engine rebuild
tdi-man Feb 22, 2013
  1. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    engines had new head fitted and new piston rings shells etc etc
    do i need to get it remapped again ?
    thanks
  2. hades-
    9,482
    646
    if you had a map it will still be there in the ECU
  3. Bramley
    Bramley Member
    389
    19
    Well surely your engine will run better now so you'd have thought you'd possibly be able to get more out of it now - so id suggest yes.
    maybe wrong tho
  4. tdi-man
    1,783
    64
    lol i know that just wonder if i need it checking
  5. hades-
    9,482
    646
    it wont need checking
    rebuilding engine wont change the map.
  6. Bramley
    Bramley Member
    389
    19
    Of course the map hasnt changed but in theory the engine has
  7. hades-
    9,482
    646
    unless its a full on custom map it would only be the ame if it was reflashed
  8. tdi-man
    1,783
    64
    it is a custom map with a hot start fix in the map and i was wonder if the hot start probelm was down to the fact that the cracks in the head are in the glow plug holes
  9. hades-
    9,482
    646
    dont worry about it
    so you have a stage 1 remap
    i ment a full on big turbo stage 3 custom map
    it will be ok
  10. tdi-man
    1,783
    64
    i do have a hybrid turbo with full egr delete
  11. hades-
    9,482
    646
    so i take it you still have ther same set up nothings changed
    then you should be ok
    but by all means spend some money for the fun of it
    when i had my stage 3 rebuilt with new cams and head both times the map was still the same
  12. tdi-man
    1,783
    64
  13. TDI140
    TDI140 Well-Known Member
    1,632
    175
    Map is programmed to ecu so should be all there but worth getting it tweaked for your new built engine as all components are new and will be working much smoother that way you might get more bhp
  14. Boon
    Boon Active Member
    441
    59
    You say you had a hot start map done so was the hot start rectified with this?
    I also have had a hot start map replaced/tweaked and mine has been brilliant, neither the starter or battery has been changed. (Anyone with a hot start issue should unplug the temperature sensor located under the fuel pump when at operating temperature and start the engine - if it fires up just as cold, the starter nor the battery are at fault - it's the software in the ECU)
    Oh, and your Remap will stay on the ECU, I fail to see that getting it tweaked because the engine is rebuilt will bring any gains (apart from being stronger/last longer!) Just remember to 'run it in'!
