Do I have heated mirrors?
mrmacmusic Feb 29, 2008
  1. mrmacmusic
    mrmacmusic Member
    40
    Quick question – how do I know whether or not I have heated mirrors?
    My TDI Sport 130 ('02) is going in to the dealer for a wee oil leak at the high pressure turbo hoses/connectors (?!*) and I've mentioned that the mirrors don't demist – they were one of the few things that worked properly on my previous 2.0 FSI SE (!). The dealer asked whether or not I had heated mirrors, but it suggests in the manual that they are standard across the range (no asterisk indicating they were an option).
    Can any other TDI Sport owners confirm whether or not they have/don't have heated mirrors......?
    On another note, can DIS be retrofitted? It was nice to know when I had ran out of washer fluid.......
    Cheers.
  2. 1210tech
    1210tech Four Ring Fanatic Team Daytona Team V6 Audi A6 Audi Avant Owner Group S-line owners group
    696
    mine has but i have one mirror that does demist/defrost and one that doesn't. after speaking to the previous owner it turned out that the one that doesn't had been replaced cuz it got smashed and he bought a replacement glass that didn't have the heater element built in and i just haven't got round to sorting it out.
    you can get the glass with the heater element from gsf or vagparts. the wiring to make them work should already be in the mirror housing and its just a case of plugging in the new glass and fitting.
    i have seen on other forums that the DIS can be retro-fitted but it is very expensive.
  3. Andy D
    Andy D Member
    276
    Both of mine are heated and work properly, on a cold day you can see the steam coming off of them.
    I had my mirrors off to change the mirror cases and each mirror had two wires connected to the back of it for the heating element.
    It's easu emough to take the mirror glass off to check but be careful as it's easily broken
    BTW its' a 2004 TDI 130BHP Sport, hope thius helps
  4. samuelt
    samuelt Member
    383
    i also have a 02 tdi 130 sport and no i do not have heated mirors, i have had the glass out and looked all the electrics are there but not the correct glass. they will work as they go on with the heated rear screen. i belive you can buy them at £50 a pair
  5. bonerp
    bonerp Member
    180
    mines a tdi sport without too - rubbish aint it? My first car (a cortina) even had those!
  6. Nickynibbles
    Nickynibbles Damn it where's 7th gear when you need it?!
    845
    Nonsense is it expensive to fit! All you need is a replacement wiper stalk with the controls for about £30 and probably a replacement steering wheel control module for about £85 and vagcom to code it. I say probably as most cars would need a new module but some were lucky enough to be fitted with the correct module anyway but the features not enabled. I've been researching into fitting cruise control to my car and come across how to do this in the process. If your after a washer fluid low signal this actually isnt a function of the DIS but yet another optional extra!!! This is easy to add on top of DIS though as all you need is the sensor for the washer bottle which is under £10!
  7. mrmacmusic
    mrmacmusic Member
    40
    Thanks folks – I guess I'll find out when it goes into the dealer whether or not I do have them! Sounds like not all (older) TDI Sports have 'em after all. However, if it's only going to be £50 for new glass, then I reckon I'll go for that. Steamy mirrors would have been really handy on the recent chilly Scottish mornings.......
    Also sounds like if I decide to retro-fit cruise (which I was considering), that it would make sense to upgrade the DIS at the same time.
  8. 1210tech
    696
    sorry, i was thinking of the coloured DIS which would need a whole new dashboard cluster :icon_thumright:
  9. Nickynibbles
    845
    Oh yes, the coloured DIS would cost a lot to do!!
    @mrmacmusic, definately worth having the DIS done at the same time as the cruise control. If you dant have vagcom and not doing the fitting yourself you'll save yourself labour and hassle of having your steering wheel removed twice and some coding doing to activate it all! You've got to take the wiper stalk off to fit the cruise control stalk & the new steering wheel control module so you might as well have the DIS stalk fitted & activated at the same time!!
  10. CASS56
    CASS56 New Member
    Look in boot or service book at option codes, powered & heated mirrors code is 6xd
  11. mrmacmusic
    mrmacmusic Member
    40
    Thanks Cass56 – looks like I only have powered mirrors, as my option code is 6XC. Can't believe my car has a chiller in the glovebox, but no heated mirrors!
    Is it really simply just a case of replacing the glass??
  12. Andy D
    Andy D Member
    276
    I suppose it would be if the wiring is in place, I'm not entirely convinced that the wiring will be in place.
    Have a look , honestly it takes less than a minute to take one of the mirrors off and have a look.;)
  13. CASS56
    CASS56 New Member
    6xc does indeed come up as powered only, not sure about wiring but as Andy D says it's not a bad job to check
