Do I have DIS?
TAPNET Apr 1, 2011
  1. TAPNET
    TAPNET Member
    89
    Im getting my cruise control fitted tomorrow but guy at work said i don't have DIS... im pretty sure I do though I got the display in the middle of my clocks
    Looks like that but its red has computer 1 and 2 mpg etc but I can't get into the menu system to do other stuff :| and apparently thats DIS but mines not please help me!
  2. crispin
    crispin Member
    167
    I would say you do!
  3. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,216
    305
    yes thats the dis tell the guy in work too open his eyes lol
  4. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Dis stands for driver information system
    So If you have what you show in the picture, then yes you do have dis
    What is your a3 ? Sport se s line?
  5. FranA3
    7,216
    305
    does yours look like this
  6. TAPNET
    TAPNET Member
    89
    Yes it looks like that Fran if I run low on fuel the top half changes colour and if a door is open it will show there too I can flick through different bits mpg fuel left time driving pressing reset and the buttons on the end of the washer stalk, but I looked in the manual and it said theres another menu I can get into but I can't get into that and apparently because I can't get into that menu I don't have DIS.... :|
    Its just a sport 2.0 TDi 07 plate
  7. FranA3
    7,216
    305
    then yes you have the d.i.s bud your friend has got a clue
  8. TAPNET
    TAPNET Member
    89
    Grrr he's just scaring me thinking I've wasted £60 deposit getting my cruise fitted.. twat.. thanks guys!
  9. FranA3
    7,216
    305
    lol i want to get cruise fitted sometime too its on my too do list (the list is very long)
  10. Vertigo1
    Vertigo1 Well-Known Member
    3,381
    542
    Whoa, hang on a minute guys.
    When the A3 was first released, only the Sport model got the DIS as standard. If you didn't have this or spec it as an option, then the centre of the dash was replaced with a fixed panel with "old style" warning lights for things like bulb failures and low fuel.
    At some point later they changed this so that the "base" model cars had the same physical LCD display as the DIS-equipped one but with much reduced functionality - basically it would show you simple information but the advanced features were disabled. This is still the case on the current 8P3, where the very base model doesn't have "DIS", but still has the display - just with reduced functionality.
    It may be that the OP has such a car - the display is physically present but the full "DIS" functionality isn't.
  11. TAPNET
    TAPNET Member
    89
    I can tell you guys I got my cruise fitted with no problems I have the full DIS system but without the menu part which made me panic. Infact the guy at work was playing an april fools on me too...
  12. Vertigo1
    3,381
    542
    Actually, now I think about it, wasn't the menu only added with the white DIS - ISTR the red one didn't have a menu of any kind.
  13. paddy
    paddy Audi=No fault code, no idea
    5,152
    131
    On April the 1st DIS stands for Dyslexic in control..:)
  14. pat_986
    pat_986 Member
    67
    When did this change come in? With the facelift in 2009(if thats when the face lift was?)
  15. Trevor Locke
    Trevor Locke Stockton on Tees
    69
    I know this is an old post but i can't access the menu system on mine, so if it is a reduced functionality that will explain it!
    Is there any updates or fixes to access full fuctionality????
  16. Trevor Locke
    69
    How much to add cruise control???
  17. OCD-A3
    OCD-A3 Member
    118
    You need a wiper stalk with the buttons to access the menus, should have an up/down rocker on the end and a reset button on the bottom.
  18. Trevor Locke
    69
    i have that, but holding the reset button in does nt access any menus
  19. AudiA3JJ
    AudiA3JJ Active Member
    249
    34
    Fyi.... My old 55 8P2 tdi had dis, but no where near as much functionality as my 56 sline. I had the cruise control fitted (i paid £170..all new parts fitted) ...but it turned out my 55 was fitted with an older type control unit (proberbly a factory concession?) so my cruise functioned the same as in an older golf.. Not as it should, the rocker button on the end didn't work and fee other things... It still worked but you had to use the stick differently to activate and cancel.
  20. Ash187
    7,444
    704
    We can supply cruise if anyone was interested.
