Do I have Bluetooth?
Gourlay1990 Feb 4, 2013
  1. Gourlay1990
    Gourlay1990 Member Team Glacier quattro Audi A4 Black Edition S-line owners group TDi saloon Manual
    39
    Hi folks,
    i have an Audi a3 170 TDi. I was wondering if the Bluetooth module comes standard with car? I haven't checked under the seat yet but I thought I would ask before I check at the weekend. I have the double din standard head unit if that helps?
    I appreciate any help,
  2. mmalh0151
    mmalh0151 Member
    170
    Best way is to turn car on and search for bluetooth devices with your phone.... I didnt know either till i did this!!
  3. hades-
    9,481
    646
    do you have a cradel in the arm rest or on the dash ?
    have you tried to connect your phone ?
  4. Gourlay1990
    39
    Thanks mate ill try this in the morning.
    cheers
  5. A3Kent
    A3Kent Well-Known Member Team Daytona Audi A3 S-line owners group TDi
    1,570
    249
    It's not standard. Best thing to do is search for it from your mobile to see if Audi UHV or similar appears.
  6. Gourlay1990
    39
    I had a cradle on the dash for the 4s when I had it, I have now got the 5 but when I try to connect like I used to it doesn't work??
  7. NHN
    29,351
    1,720
    As you fitted the I4 cradle in dash, then it will have BT.
  8. Gourlay1990
    39
    Ok just popped out and tried to connect via my phones Bluetooth but did not find any devices? I haven't got the cradle anymore could that be an issue?
  9. NHN
    29,351
    1,720
    Where was the cradle fitted, was it an audi accessory?
  10. Gourlay1990
    39
    It was fitted to the left of the head unit on the dash. Yes it was an audi accessory and fitted by them.
  11. NHN
    29,351
    1,720
    So there is no dash bracket fitted into the dash still, sounds like it was aftermarket not genuine audi, so doubt its got oem bt.
    You're way up there in Scotland iirc, havnt had chance to get up that way to install anything atm, otherwise I'd certainly be able to sort that for you.
  12. Gourlay1990
    39
    There is a dash mount and it was an OEM audi iPhone 4/s cradle with part no. 8T0.051.435.F.
  13. NHN
    29,351
    1,720
    Show us a pic of the dash as it is it.
